Thread started 17 Jan 2014 (Friday) 15:11
Indestructable Hard Drives
gregpphoto
Jan 17, 2014 15:11 |  #1
Im embarking in March on a grand tour of the western National Park with my lady. Gonna be rad. Figure I need to backup all my shots (bringing my MacBook along), and I want a portable HD that can take a beating. The computer will be left in the car, but I'll take the drive with me on every hike, just in case (cant afford to lose a body of work this magnificent).
Been looking at these but open to whatever works
http://www.amazon.com …rproof+external​+harddrive (external link)
http://www.amazon.com …_t1_B005EWTL7C_​B004FLQF0E (external link)
Same price just about, 250gb more for the Silicon Power. I just want the one thats most reliable and least likely to blow it. I understand too though that normally, if the hard drive works for a minute itll work a day, and if it works for a day itll work a year, etc.
Thoughts? Thanks!!
gregpphoto.com (external link)
mike_d
Jan 17, 2014 15:24 |  #2
Rugged drives are almost certainly just standard laptop hard drives in a more protective case. The drive itself can still fail so I wouldn't put too much faith in a drive being "indestructible". The only way to be sure is to have multiple copies of your files as you appear to be planning.
gregpphoto
Jan 17, 2014 15:27 |  #3
mike_d wrote in post #16613750 (external link)
Exactly. And I will, I'll have the computer and the external drive. I wonder if the drives inside these cases are any good? I have no experience with hard drives outside of Lacie.
adza77
Jan 17, 2014 16:25 |  #4
The ones above look like they're just standard HDD's - and built with some protection around them for when they're not powered up. I definitely wouldn't want to risk any impact / shock to these while they were powered up.
I'd say you'd be better off with 2 seperate HDD's wrapped in bubblewrap than just using one of those. ;)
From what I understand Solid State Drives can take a bit more of a beating than Hard Drives, due to there being no moving parts. (ie, if you drop a HDD while it's still spinning, the head can damage the platter). Of course SSD's are more expensive than HDD's to, and don't hold nearly as much.
I/O Safe have a SSD drive that's waterproof, fireproof, and if I recall correctly they drove a truck over it as well. (But far more pricier than the ones above). Not sure how indestructible you want :)
Nearly all men can stand adversity, but if you want to test a man's character, give him power. - Abraham Lincoln
RHChan84
Joined Apr 2011
Jan 17, 2014 16:49 |  #5
Anything that can take shock would be a SSD in a thick rubber case.
No moving parts in SSD might be ideal for for a more durable HD.
Canon (60D Gripped | 18-135mm f3.5-5.6 IS | 40mm f2.8 | 50mm f1.8 | 70-200 F4L IS| 430 EXII)
Tamron (17-50 f2.8 VC)
Feedback
Facebook (external link)
gregpphoto
Jan 17, 2014 17:28 |  #6
adza77 wrote in post #16613881 (external link)
Im not worried about damage while in use, Im careful, but Id like to be able to toss it in my backpack when were leaving the car for multi-day trips, sometimes up to two weeks (wonderland trail around rainier!!), and not worry about bumps dings and condensation. It would probably go in a dry sack anyway, so the idea of indestructable to me just means mostly weatherproof and mostly shockproof. I guess my only concern really is the quality of the drives themselves. Ive always used Lacie and never had a problem. I know their rugged 1tb is a nice drive but its also $50 more than the ones I linked.
Hillbille
Joined Nov 2010
Jan 17, 2014 17:47 |  #7
RHChan84 wrote in post #16613946 (external link)
+1!
An SSD is/would be the way to go. If nothing else buy a SSD and replace the HDD in your portable case. Most portable cases today are oversize for the SSD's but, you can utilize that space with foam wrapping to give the drive some extra shock resistance.
Just because something is shock RESISTANT, does not mean it is indestructible. A drive of any kind probably needs to be treated nearly as well as you would your camera.
Hillbille
Rebel T2i, XS, Rebel T3; EF-S 70 - 300mm non L; EF-S 55 - 250mm; 50mm 1.8; 18 - 55 kit; YN-560; YN-468 - Pure Fun and Raw excitement.
gregpphoto
Jan 17, 2014 17:53 |  #8
Im thinking maybe a conventional portable drive with a soft foam case oughta do it really? http://www.amazon.com …_t3_B00H4YGR48_​B00H4XH5IG (external link)
Im not river rafting with it, just backpacking, so unless I fell 50 feet and died (in which case who cares about my photos), i should be ok I think. SSD looks awesome but too pricey, I need at least 500gb and more likely a TB
Hen3Ry
Jan 17, 2014 18:25 |  #9
I did a tour around the US twice, shooting thousands of photos on the way. I bought two 2.5 inch USB drives, 340GB each. They work just fine, and seem indestructible to me. I keep them in my camera bag, and dump to them at the end of the day.
BTW, portable drives usually park their heads when they're not powered, so unless you toss it in your bag or drop it while it's running, you are unlikely to lose images. If you go for SSDs in this size, you'll be spending lot more money. Might as well just buy a whole bunch of SD cards and only use them once.
Je n'avais pas besoin de cette hypothèse-là.
mike_d
Jan 17, 2014 19:26 |  #10
Hen3Ry wrote in post #16614175 (external link)
Portable hard drives are just 2.5" laptop or 3.5" desktop hard drives in a case with a USB interface. ALL hard drives automatically park their heads when powered down. I remember having to issue a "park" command in DOS before moving 1980's PCs but its been automatic for a long, long time.
tim
Light Bringer
Jan 17, 2014 20:08 |  #11
Buy more memory cards. Back up to a disk (SSD would be most robust) as well as keeping them on the memory cards, keep the cards on your and the disk in another location.
This device (external link) may be helpful too. I have one on the way.
Snow001
Jan 17, 2014 20:19 |  #12
tim wrote in post #16614381 (external link)
This looks like an excellent product.
Can I used a CF card reader on the USB slot to access pictures from a CF card?
Snow001
Jan 17, 2014 20:23 |  #13
I found the product writeup - it supports CF. An excellent product for those long trips.
mike_d
Jan 19, 2014 01:36 |  #14
Doesn't Pelican make some very small cases? Perhaps just get any standard 2.5" USB drive and throw it in a case.
Hen3Ry
Jan 20, 2014 14:00 |  #15
mike_d wrote in post #16617470 (external link)
Fry's has cases just slightly larger than a 2.5" drive. Fits in your shirt pocket.
2,440 views & 0 likes for this thread, 8 members have posted to it.
1601 guests, 139 members online
