figo wrote in post #16618095
Thanks for taking the time to post. Usually use NoiseNinja to take care of the noise but I tried Lightroom noise reduction for this shot. Need to spend less time in post production.
If you're using Lightroom, then you shouldn't be spending a whole lot of time in post anyway. If you haven't already, make use of presets.
Lightroom's NR isn't as good as noiseninja, but it's certainly good enough. Same with sharpening. Learn what the detail sliders do, and make use of the sharpening mask slider so you're not sharpening noise in the background (hold down option/alt while dragging it to see what is being sharpened).
You're on the right track when it comes to covering the game. The action is nice, and it's good to see you making use of multiple positions and angles. Overall, PP is where your photos need the most work. They look almost unedited.
