Thread started 18 Jan 2014 (Saturday) 12:11
Full Sized or Micro SD card for my 6ooD
Colin ­ Glover
Gallery: 17 photos
Joined Aug 2012
Jan 18, 2014 12:11 |  #1
I'm buying a new memory card and have two choices, http://www.amazon.co.u​k …sr=8-13&keywords=sd+cards (external link) for a Toshiba Micro SD and adapter, or a Transcend http://www.amazon.co.u​k …sr=8-51&keywords=sd+cards (external link) . Both are Class 10. Do micro SD cards have problems in DSLR's due to the adapter and data problems? Which would you buy of those two?
Regards,
Col.
Canon EOS 70D, Canon EOS 600D, EF-S 18-55 ii, EF 55-200 USM ii, EF-S 75-300 iii, Tamron 28-80, Sigma 70-210. Pentax 50mm, Pentax 135mm, EF-S 55-250, Raynox Macro adapter, Neewer filters (CPL, UV, FLD & ND4), Fuji HS20 EXR (30X zoom ) & cable release, Yongnuo 560 iii & Luxon 9800A manual flashguns for the Fuji, Hama Star 63 tripod, Hongdek RC-6 remote control, Velbon DF 40 www.point-n-shoot.co.uk website.
chubbyone
Joined Mar 2013
Jan 18, 2014 13:26 |  #2
http://www.amazon.co.u​k …words=sandisk+c​lass+10+SD (external link) Get That.
6D | EF 35 f2 IS | EF 50 f1.4 | EF 85 f1.8 | EF 135 f2.0
stpix
Joined Mar 2013
Jan 18, 2014 14:21 |  #3
I agree with this. I use that card in my T3i and its absolutely reliable.
I would never choose to use a card that required an adapter unless I had a really compelling reason to use the card in other devices too that required it.
7d T3i EF-S 10-22 EF-S 17-55 EF-S 18-55 EF-S 60 Macro EF-S 55-250 EF 400 mm 5.6 L EX 430
http://stpix.smugmug.c​om (external link)
BrickR
Joined Mar 2011
Jan 18, 2014 14:46 |  #4
You can use a micro SD card with adapter in your camera, but why? You're adding another connection. Camera to adapter to card. Why not just get a full sized card and only have to go camera to card? I'm with stpix, I wouldn't use a card needing an adapter unless I had to (like a voice recorder that only uses micro SD cards, and using the adapter to use the card in my laptop for downloading).
My junk
The grass isn't greener on the other side, it's green where you water it.
jhartley
Joined Aug 2013
Jan 18, 2014 15:51 |  #5
I've used one that was a class 10 and I have a regular sized SD card that is a class 10 both Sandisc and both 16gb and the micro with the adapter is slower. I can take about half as many pictures before the buffer is full. Go with the full sized card to save some headache on yourself.
70D 18-135 STM, 10-22mm, 24mm STM, 40mm STM, 55-250 STM, 270EX II
Colin ­ Glover
Gallery: 17 photos
Joined Aug 2012
Jan 18, 2014 18:53 |  #6
stpix wrote in post #16616130 (external link)
I read a chart on the Canon USA forum that the new U1 cards aren't compatible with the T3i/600D, yet you say you're using one? I'm puzzled by the conflicting info. Also, there's a Transcend U1 card for couple of pounds extra than the straight class ten, but the Sandisk is a third dearer. Both Transcend U1 and Sandisk are 45 mbs cards. Will there be a big difference in the two cards?
Regards,
Col.
1,098 views & 0 likes for this thread, 5 members have posted to it.
1679 guests, 103 members online
