Thread started 05 Feb 2006 (Sunday) 13:52
Underneath
Califfoto
Feb 05, 2006 13:52 |  #1
This tire was in the middle of the Bayshore in Redwood City. Sometimes the drought makes us see what is burried underneath ....
This is a shot with my Canon Rebel (external link). For this one I used the Canon 75-300mm USM IS (external link). I am pretty happy with the f-stop, but still very frustrated with the softness ...
The exif info is posted under the comments tab on my personal website (external link).
All suggestions are greatly appreciated.
Thanks in advance.
Website (external link) - Cameras: Cosina Voigtlander Bessa L, Canonet GIIIQL17, Canon eos300D&30D,Fuji Finepix 2800z,Zenith122 - Lenses:Canon 75-300mm USM IS, 18-55mm f/3.5-5.6, 50 f/1.8, EF 35mm f/2,Voigtlander 15mm f/4.5 - Filters: 52&58mm circular polarizers
Robert_Lay
Feb 06, 2006 01:11 |  #2
I have no idea what that means to be happy with the f-stop. I am also very curious when someone expresses concern about the "softness". If they were bolting the camera down in the lab and shooting a resolution target and not getting numbers that compare with those taken by professionals who make their living in scientific testing, then I would find it worth worrying about. Otherwise, no! There are too many things like not being on a tripod, or not focusing correctly or having direct rays of the sun hitting the lens or the subject being in motion, etc., etc. - any of which can lead to "softness".
Anyway, back to your image. It is nicely composed and has a full range of tones for a low key picture. Perhaps the only thing negative is the subject itself, which as you say, makes one wonder what all lies beneath the surface.
Nicely done!
Bob
Quality of Light (external link), Photo Tool ver 2.0 (external link)
Canon Rebel XTi; EF-S 10-22mm f/3.5-f/5.6 USM; EF-S 18-55 mm f/3.5-f/5.6; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.4 USM; Canon Powershot G5; Canon AE1(2); Leica R4s; Battery Grip BG-E3; Pentax Digital Spotmeter with Zone VI Mod & Calibration.
ajbalazic
Joined Jan 2005
Feb 06, 2006 12:00 |  #3
If by f-stop you mean to say you are happy with the depth of field- I think it is good too. As for softness- it looks okay to me, but if you want it sharper, use unsharp mask. It's a nice shot, well composed, but doesn't really "grab" my attention.
Alan
blue_max
Feb 06, 2006 12:28 as a reply to  @ ajbalazic's post |  #4
The usual curves tweak and sharpening does improve the shot. I have done one if you would like to see. Probably best if you change your signature/avatar to reflect that you don't mind edits though. Unless of course, you do.
Graham
Lamb dressed as mutton.
Califfoto
Feb 08, 2006 23:55 as a reply to  @ blue_max's post |  #5
Graham
I would love to see your edition. I looked for the option you suggested but didn't find it. Could you please educate me as to how I can authorize editions?
Thanks in advance.
Califfoto
blue_max
Feb 09, 2006 01:15 as a reply to  @ Califfoto's post |  #6
Hi,
It's user CP and edit profile.
Here you go. Helps a bit.
Graham
Califfoto
Feb 09, 2006 10:56 as a reply to  @ blue_max's post |  #7
blue_max wrote:
Hi,
Graham
Woah...
This is amazing. Would you mind sharing how you did this? I have photoshop CS and use one of Fredmiranda's plugins to sharpen. Are there any specific readings that I should use with the Unsharp Mask function?
Thanks a lot
blue_max
Feb 09, 2006 12:36 as a reply to  @ Califfoto's post |  #8
Califfoto wrote:
Woah...
Thanks a lot
I use FM plug-ins for sharpening. I used the medium one. Before that I just used the curves dialogue box. It alters as you fiddle, so have a go. I basically made a bit of an 's' curve, where I put a point about a third of the way up and dragged down to lighten the highlights and the same, but opposite on the shadows. It basically adds contrast. The sharpening does have a slight contrasting effect too.
The major drawback with the shot is the amount of mid-grey in the background. Other than that, it seems to work for most shots that people post. I think a lot of shooters are unaware of how good their shots can be with just a little help from photoshop. It still needs a bit of vision in the shooting though!
Graham
Califfoto
Feb 09, 2006 13:19 as a reply to  @ blue_max's post |  #9
Graham
Thanks so much Graham for the edit and all your guidance that I will try to apply to my future shots. I've recently started to play around with a couple of rangefinders (Voighlander Bessa L (external link) and Canonet QL17 GIII (external link) ).
I have the feeling that I'll be using your technique with these shots quite often.
I'd love to have your comments on these shots (HERE (external link))
blue_max
Feb 09, 2006 14:53 as a reply to  @ Califfoto's post |  #10
Hi,
I think you mistake me for a photographer!
I have a camera and know my way around photoshop, but feel ill equipped to be able to comment on a body of work.
If there is no point of reference in a shot (for example a face), then it is preferable to achieve as wide a gamut of shades as is possible. There ends my philosophy! Your shot was slighly compressed in the grey area and was improved by adding a little more contrast. You can go as far as the whites retain any significant detail and the shadows don't fill in.
The sharpening will add a little too.
Hope you have a play and see if you can tease a little more out of some of your shots.
Thanks for the comments though, it is very satisfying to think that I may have given someone a little help along the way.
Enjoy your photography.
Graham
nb I had a quick look and think you have a lot going for you.
1,302 views & 0 likes for this thread, 4 members have posted to it.
Underneath
2283 guests, 131 members online
