Thread started 19 Jan 2014 (Sunday) 20:11
Problem with image sharpness
Etude
Joined Jan 2014
Jan 19, 2014 20:11 |  #1
Hi guys,
I'm having a problem with image sharpness that seems to be ongoing.
Canon EOS 1000D with a standard 18 - 55 entry level Canon lens that came with it F3.5 - 5.5. I realise this is a cheap lens on an entry level DSLR, but I must admit I expected sharper images would be possible.
First step I took to try to improve this was removing the cheap UV filter. No difference noticed.
Here is an example:
IMAGE: http://www.redspade.com.au/audio/images/HE2.jpg
In particular the vertical lines of the veneer should be sharp. The corrugated surround around the outside of the woofer (just a little in from the edge) should also be more defined, but they are just slightly blurry.
The problem persists when using a very solid tripod, small apertures and studio flash. (as was the case here)
I have a bit of a problem focusing at times - it tends to hunt, so I might turn the camera to find a sharp line (say on the edge of the box), then turn the camera back to where I want the view.
This happens often enough that I think I can rule out obvious mistakes like focusing in the wrong place, slow shutter speed, wide open aperture, etc.
What I'm really wondering is if I'm going to need to spend more to stop this happening. I'm on a budget, but one option I'm considering is a good quality F1.4 prime lens. The camera kit with the two teles was about AUD $750 and it seems I'm spending about half that to get a good simple prime lens, for those times when I'm setting up the tripod and flashes and want to get something sharp.
Appreciate your feedback.
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Jan 19, 2014 20:16 |  #2
How far away are you shooting from? This just looks like depth of field issues, at least from what can be seen here.
Etude
Joined Jan 2014
Jan 19, 2014 20:31 |  #3
In this case it would have been 1.8m, would have been about F11, ISO 100. The speaker in question is about 28 x 28 cm with the focus set on the vertical edge in the middle of the photo.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Jan 19, 2014 20:41 |  #4
No, you were at f8. At the settings you mention, only about 1/3m would be in focus, and the focal plane is parallel to your sensor, so shooting down at an angle would have further exasperated the focal plane so that the base was out of focus.
Gregg.Siam
Joined Jun 2010
Jan 19, 2014 20:45 as a reply to  @ Snydremark's post |  #5
All lenses and bodies need to be micro-adjusted for AF. Some primes are not too bad, but over 90% of the lenses I have tested needed at least +/-5 MA. Unfortunately, the body you have doesn't allow for this. The only thing you can do is send both the body and lens to the factor for calibration, or try a prime and hope you get lucky.
5D MKIII | 24-105mm f/4 L| 50mm f/1.8 | 600EX-RT [FONT=Tahoma][COLOR=bl​ue][FONT="]|
∞ 500px (external link)
Snydremark
Gallery: 66 photos
Jan 19, 2014 20:50 |  #6
EXIF says that the settings were 48mm, f/8, 1/80, ISO100. Which, at that distance, would only give you about 42cm, total, DoF. Add that to the fact that you're shooting at an angle and with the speaker rotated, wouldn't necessarily give you the greatest results.
If it's an option, I'd try moving back and shooting at a longer focal length, drop your aperture to f/11 or so and square up on the speaker a little bit better (not so much of a downward angle.
xarqi
Jan 19, 2014 21:12 |  #7
Specifically, which 18-55 lens?
vengence
Joined Mar 2013
Jan 19, 2014 21:15 |  #8
Snydremark wrote in post #16619614 (external link)
Moving back won't change anything if he doesn't change his framing. He could shoot it with a 500mm at f/8 with the same framing and he'll still have the same DoF.
Etude
Joined Jan 2014
Jan 19, 2014 22:52 |  #9
Thanks for the responses all.
Gregg,
How far up the food chain do I need to go to be able to get this adjusted? I must admit, this is the first I've heard of this. Where does one get this done? (I'm in Australia).
I have a 300mm tele also and I could in another room shoot up to say 5m and try reducing the angle. I could also try manual focus, bit sad if I need to resort to that. Will also try changing the aperture.
The Lens is a Canon EFS 18-55 1:3.5-5.6 58mm. Would a prime lens mean a significant difference here?
EOS5DC
Joined Dec 2013
Jan 19, 2014 23:03 |  #10
P&S is what you need for super-deep DOF at narrower apertures and close subjects. SX50HS? At ISO 100 and with adequate lighting, you'll lose next to nothing in IQ.
Bodies: 60D, 6D.
EFs: 15-85, 10-22
EF: 28-75, 35 f/2 IS, Σ70-200 OS, 100-400L
Flash: 580EX II, 430 EX II
Etude
Joined Jan 2014
Jan 19, 2014 23:19 |  #11
Didn't see that suggestion coming! As it turns out, there is a camera like that I can borrow to try and see what kind of result I get.
xarqi
Jan 20, 2014 00:42 |  #12
Etude wrote in post #16619906 (external link)
Ah - I may be able to see your problem.
There have been a great many 18-55 lenses, maybe at least 6. Until the first IS lens came out, they were all bad. Unless you happen to have the Mark III non-IS version, or you haven't mentioned that it has IS or is the STM lens, then it is one of the bad ones. Even stopped down these are disappointing, in my view. That isn't to say that nobody has ever taken a great image with one of them of course.
Of the bunch, the Mark III, or any with IS is tolerable, and the STM lens quite decent for the price.
Etude
Joined Jan 2014
Jan 20, 2014 03:36 |  #13
Well, it has II on it so I'll assume that means Mark II. So it would seem I have a bad lens.
xarqi
Jan 20, 2014 04:22 |  #14
Etude wrote in post #16620244 (external link)
Unless it is the 18-55 IS Mk II.
I'm not saying that there may not be other reasons for your dissatisfaction with the particular image posted, DoF or whatever, but you should be aware that the EF-S 18-55 Mk II is considered optically (and indeed physically) quite poor. It's something that I'd recommend you consider replacing as funds permit. You need not spend a fortune to get something better, but exactly what does depend on your photographic aspirations.
Options would include, in increasing order of cost: the 18-55 IS Mk II, the 18-55 IS STM, the 18-135 IS STM, the 15-85 IS, and the 17-55/2.8 IS.
There are also offerings from Sigma and Tamron that are well respected.
Snowyman
Gallery: 682 photos
Joined Oct 2011
Jan 20, 2014 04:25 |  #15
Tripod and focus stacking.
Snowy's Gear
Deviant Art (external link)
2,872 views & 0 likes for this thread, 13 members have posted to it.
1799 guests, 133 members online
