agv8or wrote in post #16628300
This ring from Adoroma will fit it. Same ring is sold at B and H but with a 7-14 day delay.
http://www.adorama.com/BZRD6210.html
I have several of these as well as the SP Studio ones and they are the same size.
The Fotodiox and Studio Solution adapters are larger than those used in the SP studio folding soft boxes and the Bowens folding speed rings.
Those inserts do fit and I own one but I would also advise anyone to avoid them like the plague. Observe:
Notice that the insert on top has square cross section lugs while the other has rounded lugs. You might also be able so see that the lower insert has a slightly smaller diameter than the one on top. Both of these characteristics spell HUGE potential trouble.
In brief, because of the rounded lugs and smaller diameter, the insert on the bottom has a very strong desire and the ability to over-rotate in a Bowens mount. That is, when inserted in the mount, instead of only rotating a few degrees and stopping, it can bypass the internal stop and continue rotating. This is VERY bad.
Look at the right hand image: See the tensioning leaf spring inside the Bowens mount? Well, the insert with the rounded lugs will slide right over the top of the spring never to return. Once that happens, the three internal leaf springs pop back up and prevent the insert from retracing its steps and being removed from the mount. The insert is held captive at this point.
Just to make the situation a bit more frustrating, the mount cannot be disassemble because the screws that hold it together are inside the mount.
Having had this happen twice, I can tell you that getting the insert off the mount requires three razor blades (to depress the leaf springs), lots of patience, and several Band-Aids.
Bottom line: Do yourself a favor and do not get this insert.
