Instead of inputting an f-stop value yourself, input the depth of field that you want to achieve and let the camera figure out what the distance to subject is. You'd also need to input the output size, viewing distance and viewer's visual acuity.
How would it work? Let's say that you want to end up with 16x24" prints viewed from 3' by a person with 20/20 vision, so you enter those numbers into the camera. The camera will know the distance to subject and the circle of confusion already. You just select that you want a 6' depth of field, for example, and the camera will figure out the f-stop for you.
Benefit? When I am photographing an individual that is not stationary, I need to constantly change the f-stop based on their distance. If I want just the person to be in focus to get that awesome background separation, I'll use f/1.4 for full body shots, f/2.8 for half-body, and f/5.6 for head/shoulders. If there was a mode like the one described above, I could just set all the variables ahead of time and not have to change any settings as the person moves closer or further. If another person joins the first and I need a 3' depth of field, I just make that change once and continue shooting.
What do you think? Would this be a useful feature?
(24Lii, sigma 50A, 135L), and for the other ends of the spectrum, sigmaEX 14mm2.8 and sigmaEX 100-300F4.
