Thread started 24 Jan 2014 (Friday) 12:16
Gitzo leveling base
nellyle
Joined Jan 2012
Jan 24, 2014 12:16 |  #1
I would be very grateful for some help!
I have a Gitzo 1325 mk2 (so not a current one) tripod that I would like to fit with a leveling base.
Can I use the current Gitzo offering? Or, do I have to try and find one from the same period!?
5D3, 7D2, 1D3, 40D, 14 f2.8 Samyang, 17-40 L, 28-80 L, 70-200 2.8ii L, 200 2.8ii L, 200-400 L, 1.4 ii,
http://chris-stamp.smugmug.com/ (external link)
johnf3f
Jan 24, 2014 13:35 |  #2
My G1329 uses the same top plates as my GT3230LS so you should be fine with your 1325.
Life is for living, cameras are to capture it (one day I will learn how!).
nellyle
Joined Jan 2012
Jan 24, 2014 13:46 |  #3
That's good to know, thanks!
seres
Joined Apr 2013
Jan 24, 2014 14:32 |  #4
The current Gitzo leveling base fits 3 and 4-series models from the 1980's, well before Gitzo started using the 4-digit model numbers. So yes, it will fit.
—Eric
SkipD
Joined Dec 2002
Jan 24, 2014 16:04 |  #5
I use a Manfrotto leveling base on one of my tripods, particularly when I'm using a two-axis fluid head. The head does not tip, so I get it level from side-to-side with the leveling base.
There are tricks you can play by deliberately setting the leveling base off-level as well. It's a good tool to have.
Skip Douglas
nellyle
Joined Jan 2012
Jan 25, 2014 07:36 |  #6
Thanks for the help, I was worried I'd spend a few hundred and find out they weren't matched!
1,098 views & 0 likes for this thread, 4 members have posted to it.
Gitzo leveling base
1193 guests, 136 members online
