Do you guys use/have desiccant/silicon beads in your bags to stop moisture/fungus/mold?
Africanphoto Member 124 posts Joined Sep 2012 Location: Australia More info | Jan 24, 2014 20:55 | #1 Do you guys use/have desiccant/silicon beads in your bags to stop moisture/fungus/mold? Canon 7D, Canon 100mm L F2.8, Sigma 120-300mm F2.8 OS, Sigma 50mm F1.4, Canon 430 ex II, Sigma 2x teleconverter, Kenko extension tubes, Vello flash cord And a few bits and peices and a Yashica 635!!!
Jan 24, 2014 20:56 | #2 I throw the pouches that come in boxes from other items into the bag for the heck of it. Why not is my thought. Andrew | Midwest Automotive
ten31 Member 120 posts Joined Nov 2006 Location: Miami, FL More info | Jan 24, 2014 21:07 | #3 Myboostedgst wrote in post #16634525 I throw the pouches that come in boxes from other items into the bag for the heck of it. Why not is my thought. This. Canon EOS 6D | 24-105mm f/4 IS USM | 85mm f/1.8 | 430EX II | Mefoto Roadtrip | RC6 remote
JohnfromPA Cream of the Crop 11,257 posts Likes: 1526 Joined May 2003 Location: Southeast Pennsylvania More info | Jan 24, 2014 21:13 | #4 Nope. In my climate, southeast Pennsylvania, never had any issue related to humidity, I have, and use on occasion, a camera made in 1958. No humidity issues whatsoever.
LVMoose Moose gets blamed for everything. More info |
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Jan 24, 2014 21:52 | #6 Africanphoto wrote in post #16634519 Do you guys use/have desiccant/silicon beads in your bags to stop moisture/fungus/mold? This is a totally useless thing to do. Skip Douglas
v35skyline Goldmember 3,572 posts Likes: 16 Joined Apr 2007 Location: San Diego, CA More info | Jan 24, 2014 22:33 | #7 I use "rechargeable" desiccant packs in my Pelican case. X100s | X-Pro1 | X-T1 | XF 14 | XF 18 | XF 35 | XF 56 | XF 60 | XF 10-24
bidkev Goldmember 4,847 posts Gallery: 2123 photos Best ofs: 3 Likes: 12862 Joined Jul 2013 Location: From Blackpool UK to Brisbane Australia 20 yrs ago More info | Jan 24, 2014 22:41 | #8 Agree with Skip which is why I keep my gear in a large (40 litre) cool box with a rehcargeable dessicant pack. It rarely needs re-charging as the only moisture in there is from when I open the lid to take some gear out, effectively (unavoidably) trapping a small amount in. I live in a sub-tropical climate and it can get quite humid in summer. See my fishy photography here: https://kevindickinsonfineartphot.smugmug.com/Tropical-Fish-2/
s.l.k Member 143 posts Joined Mar 2012 Location: Oregon More info | Jan 25, 2014 01:52 | #9 v35skyline wrote in post #16634715 I use "rechargeable" desiccant packs in my Pelican case. http://www.amazon.com …0037Z8K3E/ref=pd_sim_hg_6 Same here.
Lowner "I'm the original idiot" 12,924 posts Likes: 18 Joined Jul 2007 Location: Salisbury, UK. More info | Jan 25, 2014 06:08 | #11 No, just not needed here in the UK. Granted we do get our fair share of rain, but it normally dries naturally. Richard
KirkS518 Goldmember 3,983 posts Likes: 24 Joined Apr 2012 Location: Central Gulf Coast, Flori-duh More info | Jan 25, 2014 17:44 | #12 SkipD wrote in post #16634629 This is a totally useless thing to do. Desiccant doesn't do any good unless it's used in an air-tight space because unless the space where the desiccant is used is air-tight, water vapor from around the space will replace the water vapor that was adsorbed by the desiccant almost immediately. No conventional camera bag is air-tight. Desiccant bags would only take up otherwise useful space in the typical camera bag. I kind of question the 'science' behind this. You would need airflow to re-introduce moisture-laden air, and the volume of moisture adsorbed/absorbed by the desiccant would be minuscule, so any air that replaces the removed volume of moisture would also be minuscule. The desiccant would then adsorb/absorb that new moisture, and it becomes a half-life type of cycle, wouldn't it? ie, the amount of moisture that has been re-introduced, but exceeds the capacity of the desiccant would not be enough to have an impact on anything. If steroids are illegal for athletes, should PS be illegal for models?
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Jan 25, 2014 18:38 | #13 KirkS518 wrote in post #16636551 You would need airflow to re-introduce moisture-laden airWater vapor in the air does not need conventional air flow to migrate from a moist environment to a dry environment. While I cannot quote the science facts involved, it has to do with vapor pressure. Vapor pressure is constantly trying to equalize. Skip Douglas
JohnfromPA Cream of the Crop 11,257 posts Likes: 1526 Joined May 2003 Location: Southeast Pennsylvania More info | Jan 25, 2014 20:58 | #14 Priceless, and one for the books!
NU27D Senior Member 464 posts Joined Dec 2010 More info |
| Latest registered member is ANebinger 1095 guests, 173 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
