Thread started 25 Jan 2014 (Saturday) 10:21
DPP cropped image file size much bigger than original. Why?
colintf
Joined Apr 2012
Jan 25, 2014 10:21 |  #1
Hi,
Played with DPP today cropping some JPEG images
What I don't understand is why the cropped image has a much bigger file size than the original say 4Mb vs 1.6 for example
Any ideas?
What am I doing wrong?
Many thanks
Cheers
Colin
tzalman
Fatal attraction.
Jan 25, 2014 11:06 |  #2
Because at its highest quality setting DPP compresses jpgs much less than the camera. The camera has only two compression levels, one is equal to DPP 7-8 and the other 3-4. DPP 10 makes for larger files.
Elie / אלי
BigAl007
Gallery: 542 photos
Jan 25, 2014 11:15 |  #3
When you save the cropped image DPP starts all over again using the JPEG file compression system, as if the image had never been compressed before. If you have the maximum image quality/ largeest file size selected then the resulting file will be much bigger. Although you have set the image quality to maximum the "damage" that file compression does to the image quality from the initial smaller file size is still there and cannot be undone.
When editing JPEG files it is always best to create a copy when you save so that you still have the original file, good if you change your mine on the edits you have done. Every time you open a JPEG file, edit it and then simply re-save it you will reduce the quality of the file, as the compression system is run on the data each time, slowly adding to the "damage" each time.
Do not worry unnecessarily as the damage from doing it just once is usually pretty negligable, and usually needs a trained eye to see.
Alan
My Flickr (external link)
tzalman
Fatal attraction.
Jan 25, 2014 11:27 |  #4
colintf wrote in post #16635616 (external link)
Hi,
Any ideas?
Many thanks
Cheers
Colin
You didn't say what camera you have, but if it's one of the current 18 MP models its 8 bit image without compression would be around 50 MB, so if you are getting 1.6 MB jpgs that is an awful lot of compression.
Elie / אלי
colintf
Joined Apr 2012
Jan 25, 2014 12:25 |  #5
[many thanks guys :cool:
QUOTE=tzalman;16635786​]You didn't say what camera you have, but if it's one of the current 18 MP models its 8 bit image without compression would be around 50 MB, so if you are getting 1.6 MB jpgs that is an awful lot of compression.[/QUOTE]
I was cropping an already cropped image :cool:
1,023 views & 0 likes for this thread
Latest registered member is Peterzzzzzz
774 guests, 374 members online
