Q. Am I right that means the 40 mm pancake is front focusing?
As I understand it ; a positive MFA number means it will shift the focus point further away behind the standard auto focus point.
Looks like the two L lenses are smack on zero.
All assuming using the dot tune method my first zero shot was in focus.
I am a bit unsure of one aspect of the Dot Tune method.
Should your first AF try just be left at zero, to calculate the in focus values positive and negative, and then calculate the mid point. And set that as the MFA amount.
I need to carefully review all the respective images before saying whether it works for me.
I always felt the two L lenses were extremely accurate,and the 40mm very good. But then a suppose +3 is not a lot.
