Thread started 26 Jan 2014 (Sunday) 08:23
Ditch my 100-400 ?
alexxn
Joined Nov 2011
Jan 26, 2014 08:23 |  #1
So after time has gone by I find myself rarely using my Canon EF 100-400mm f/4.5-5.6L IS anymore, I can usually get the reach I need with my 70-200 f/2.8L IS.
However, there still have been times (especially with surfers) that I didn't have enough reach with the 70-200.
That being said, is there any image quality difference between the 100-400 and the 400 f/5.6 ?
Here are my thoughts / options:
1) Sell the 100-400 and pick up a 400 f/5.6
2) Sell the 100-400 and pick up a 300 f/2.8 (and a converter also)
Keep in mind these would be primarily used with my 1Dmk4.
Opinions ?
Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
www.alexnikolis.com (external link)
MCAsan
Joined Jun 2010
Jan 26, 2014 08:46 |  #2
Depends on what you shoot. If you can zoom by walking around or plan to crop...OK. Personally I always want a high quality zoom when I shoot wildlife. Note I am not a birder.
Tapeman
Sliced Bread
Joined Jan 2004
Jan 26, 2014 08:48 |  #3
I would recommend the 300 f/2.8L IS. I have owned one and used it a lot of the time with converters on a 1D4. I miss mine. (sold it to help finance the 500)
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
alexxn
Joined Nov 2011
Jan 26, 2014 08:51 |  #4
MCAsan wrote in post #16637875 (external link)
So which option are you recommending ? Note, I'm not a birder either :)
gasrocks
Jan 26, 2014 10:21 |  #5
Sell the 100-400. You can always get another if you miss it too much.
Scott ­ M
Gallery: 111 photos
Jan 26, 2014 10:39 |  #6
If you only rarely need more reach than with your 70-200 f/2.8 IS, you may want to consider selling both the 100-400L and 70-200, and upgrading to the 70-200 MkII and adding a 2x TC for those rare times you need 400mm worth of reach.
The 100-400L is one of my most-used lenses, but I like to shoot wildlife, plus we go to our local zoo a lot (we have a membership).
Photo Gallery (external link)
alexxn
Joined Nov 2011
Jan 26, 2014 10:52 |  #7
There are times when I will need the reach though so I was thinking fast lens -
I was mainly wondering about the image quality difference between the 100-400 and the 400 f/5.6 and if it would make sense to do the switch.
Obviously the 300 f/2.8 would be better but with a much higher price tag it's only an option if the 400 f/5.6 isn't much better than my current 100-400.
I mainly shoot freestyle jet ski and surf at this focal length.
gasrocks
Jan 26, 2014 12:39 |  #8
What is your budget?
alexxn
Joined Nov 2011
Jan 26, 2014 13:06 |  #9
gasrocks wrote in post #16638472 (external link)
Depends on which direction I go in
effstop
Jan 26, 2014 13:22 |  #10
I used my 100-400mm for surfing but ditched it for the 400mm 5.6. I like that it's lighter, the af seems a little quicker, but couldn't tell too much difference on iq. I've chewed about a used 300mm 2.8 but I can't wrap my hands around the price tag. If you can afford the 300mm 2.8 that would be a smoking option.
5D MKI | 1D MKII | 24-70mm 2.8 L | 80-200MM 2.8 L | 400mm 5.6 L |50mm 1.8
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Jan 26, 2014 14:54 |  #11
Heya,
Going to the prime gives you faster AF, lighter weight, slightly sharper image (negligible unless you pixel peep really). The 300mm is a great lens, but you're already thinking of a teleconverter and stopping it down to F4 (1.4x TC) or 5.6 (2.0x TC). So you're trading a 400mm F5.6 lens for a 420mm F4 lens, but at quite a big cost disadvantage. I don't think the 20mm difference, and single stop of light difference is worth that cost change.
Do you need this wide of an aperture anyways? You're shooting in bright light I assume, doing stuff in the surf on nice days. Considered a 500mm? You don't need F2.8 for this. They're not falcons at 100 yards.
Very best,
ERJL
Joined Dec 2012
Jan 26, 2014 15:06 |  #12
alexxn wrote in post #16637831 (external link)
Opinions ?
Rumors are that Canon "may" introduce a replacement for the aging 100-400 design this year. It is a great lens now matter how old the design is but, if you are considering dumping it sooner might be more profitable than later.
-ERJL
phreeky
Jan 26, 2014 20:44 |  #13
The 300 sounds great but do you really want to spend that much? It's on another level financially, and if you don't need the bigger aperture perhaps a waste of money too.
I'm a 400 F/5.6 owner and think it's great. It will give you a sharp 560mm F/8 with AF on your bodies too. Most 100-400 owners will claim that the 100-400 is just as good but my opinion differs, especially in regards to how the OOF areas look in the immediate foreground/background.
I'm not too sure what the third party long zooms render images like, but it might be worth looking for samples - for example the new Tamron, as if you can stop down a little the sharpness will be fine, then it comes down to the rest of the image quality/lens attributes.
alexxn
Joined Nov 2011
Jan 26, 2014 20:50 |  #14
phreeky wrote in post #16639652 (external link)
In all honesty I really don't need to go down to f/2.8….
birder_herper
Jan 26, 2014 20:54 |  #15
The 400L should autofocus considerably faster than the 100-400L...and I'd imagine be a bit sharper as well. There is sample variation, however.
Another option might be to look into the Canon 300/2.8 non-IS. The 400L would probably be about $900 used, the Canon 300/2.8 non-IS around $2000 (I've seen them for lower; there is one under $1600 now but it is too beat up for me), and the 300/2.8 IS (version 1) for about $3600. I'm unsure, but I'm guessing the optics on the 300/2.8 non-IS are about as stellar as the IS version 1. But note that it might not be easy to get parts for if something malfunctions!
9,623 views & 0 likes for this thread, 26 members have posted to it.
Ditch my 100-400 ?
1263 guests, 173 members online
