Thread started 26 Jan 2014 (Sunday) 10:19
Canon 40D Burst Rate in AI Servo
HarryImp
Joined Oct 2013
Jan 26, 2014 10:19 |  #1
Hi all,
I have got a new 40D and just have a query. When I am on MF, everything is fine, as it is with One Shot or AI Focus. But when I use AI Servo, the burst rate drops by about half to around 3fps. Is this a fault or is this normal?
Thanks in advance
Harry
EOS5DC
Joined Dec 2013
Jan 26, 2014 11:06 |  #2
40D has two 'continuous' modes. Make sure you have the high-speed one selected.
From page 81 of the manual:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/01/4/LQ_675123.jpg
Image hosted by forum (675123) © EOS5DC [SHARE LINK]
Bodies: 60D, 6D.
EFs: 15-85, 10-22
EF: 28-75, 35 f/2 IS, Σ70-200 OS, 100-400L
Flash: 580EX II, 430 EX II
HarryImp
Joined Oct 2013
Jan 26, 2014 11:09 |  #3
I have, the camera is at full 6.5 until I put it into AI Servo?
Harry
EOS5DC
Joined Dec 2013
Jan 26, 2014 11:14 |  #4
HarryImp wrote in post #16638283 (external link)
Harry
What mode are you in? M, Av, Tv, etc.
One-shot, AI-Focus and AI-Servo are FOCUS modes, they have nothing to do with frame rate.
Does the 40D have "high-ISO noise reduction"? If that is ON, it slows down my 60D considerably.
Bodies: 60D, 6D.
EFs: 15-85, 10-22
HarryImp
Joined Oct 2013
Jan 26, 2014 11:20 |  #5
I am on AV. I don't understand how it's the case but the others are fine.
HarryImp
Joined Oct 2013
Jan 26, 2014 12:19 |  #6
I have been experimenting a little more. When I removed the battery grip it worked as normal, then put the grip back in was slow again. Guessing the grip is just faulty??
John ­ from ­ PA
Joined May 2003
Jan 26, 2014 12:31 |  #7
HarryImp wrote in post #16638436 (external link)
Sometimes grips have two batteries, one of which in your case might be weak. If your grip uses two batteries, try each in the body and see if you detect a difference.
Levina ­ de ­ Ruijter
I'm a bloody goody two-shoes!
Gallery: 457 photos
Best ofs: 12
Jan 26, 2014 12:35 |  #8
Once upon a time one of POTN's own had the same problem. And became a legend... :D
https://photography-on-the.net/forum/showthre​ad.php?t=430473
Wild Birds of Europe
https://focusonphotogr​aphy.community.forum/t​hreads/wild-birds-of-europe.54/
Focus on Photography (external link)
WaltA
Gallery: 10 photos
Joined Feb 2006
Jan 26, 2014 12:46 |  #9
Levina de Ruijter wrote in post #16638463 (external link)
Well, the hi-speed and low-speed modes have been ruled out.
So LightRules still rules.
Walt
400D, 5D, 7D and a bag of stuff
EOS5DC
Joined Dec 2013
Jan 26, 2014 12:58 |  #10
Are you using BBAF? Does it do that if you STAY focused on the same spot? And just to confirm, you do get 6.5 fps in One-Shot mode, and it slows when going to AI-Servo without changing anything else? That is odd, indeed!
Bodies: 60D, 6D.
EFs: 15-85, 10-22
HarryImp
Joined Oct 2013
Jan 26, 2014 13:16 |  #11
John from PA wrote in post #16638457 (external link)
Thanks, I did that but both batteries worked fine and gave the full burst rate!
HarryImp
Joined Oct 2013
Jan 26, 2014 13:19 |  #12
EOS5DC wrote in post #16638513 (external link)
Sorry I'm not sure what BBAF is? Yes I do I one shot, and also with just a single battery, or when just using MF. Just with the battery pack, AI SERVO reduces the burst rate!!
WaltA
Gallery: 10 photos
Joined Feb 2006
Jan 26, 2014 13:52 |  #13
HarryImp wrote in post #16638568 (external link)
BBF - Back Button Focus
Walt
HarryImp
Joined Oct 2013
Jan 26, 2014 14:41 |  #14
No I am just half depressing the shutter?
Harry
tzalman
Fatal attraction.
Jan 26, 2014 14:59 |  #15
WaltA wrote in post #16638649 (external link)
BBAF _ Back Button AWESOME Focus
Elie / אלי
7,776 views & 0 likes for this thread, 16 members have posted to it and it is followed by 4 members.
2566 guests, 92 members online
