Thread started 26 Jan 2014 (Sunday) 14:29
Canon 6D Flash High Speed Sync questions?
erikfig
Joined May 2012
Jan 26, 2014 14:29 |  #1
Hey All,
Can I use High Speed Sync on the 6D with speed lights? I believe the 6D maximum speed sync is 1/180? Does this mean I will get the black bar on the frame if I go 1/200 and up?
Who cares about my gear?
FlickR (external link)
Facebook (external link)
xarqi
Jan 26, 2014 14:59 |  #2
The 6D supports HSS flash control with compatible flash units. I just verified this with my 6D/YN568II. 1/800 s - no problem.
EOS5DC
Joined Dec 2013
Jan 26, 2014 16:00 |  #3
HSS is what you use to avoid the BLACK BAR. You can use HSS at 1/4000 if you want. I think the max range will be something like 5 feet at ISO 800, though.
Bodies: 60D, 6D.
EFs: 15-85, 10-22
EF: 28-75, 35 f/2 IS, Σ70-200 OS, 100-400L
Flash: 580EX II, 430 EX II
erikfig
Joined May 2012
Jan 26, 2014 16:25 |  #4
Thank you guys! :D This doubt was really affecting my purchase decision.
watt100
Jan 26, 2014 17:42 |  #5
erikfig wrote in post #16638724 (external link)
Hey All,
like others have said using HSS avoids the black bar but some manual flashes (or an ETTL flash with manual triggers) can go beyond the camera's sync speed and not show a black bar
John ­ Sheehy
Jan 26, 2014 17:51 |  #6
erikfig wrote in post #16638999 (external link)
As others have said, the max power of the flash gets weaker, the faster the shutter speed in HSS mode, but at speeds up to about 500, it's generally not an issue.
Also, realize that the flash does not act much like a flash in HSS mode; IOW, it does not flash on the frame for as little as 100 microseconds as it does in normal sync mode; rather, it strobes as the shutter passes a slit over the sensor at about 1/180s, so it only adds light to the scene, but it does not freeze motion more than the ambient part of the exposure does.
Damian ­ Díaz
Joined Sep 2021
Sep 17, 2021 17:50 |  #7
Hello guys hope u can help me out here. I just bought the Neewer Q3 Speedlight and i’m using it with my Canon 6D but the High Speed issue is not working. Have anyone had that same issue??
Wilt
Post edited over 2 years ago by Wilt. (2 edits in all)
Sep 17, 2021 18:08 as a reply to  @ Damian Díaz's post |  #8
HSS needs to be enabled on both the camera and on the flash. Have you checked the menus of both?
https://www.dummies.co​m …ode-on-your-canon-eos-6d/ (external link)
Damian ­ Díaz
Joined Sep 2021
Sep 17, 2021 23:38 as a reply to  @ Wilt's post |  #9
The thing is that with a flash directly on the camera it works perfectly but whenever i put a transmitter to a flash, in this case the Neweer Q3 the “Flash Function Settings” doesn’t work!! And doesn’t allow me to activate the high speed sync.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2021/09/3/LQ_1121806.jpg
Image hosted by forum (1121806) © Damian Díaz [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2021/09/3/LQ_1121807.jpg
Image hosted by forum (1121807) © Damian Díaz [SHARE LINK]
Wilt
Sep 18, 2021 00:13 |  #10
So you just pointed out the gremlin....the on-camera transmitter must have software version that does not properly work with the camera's eTTL support of HSS
apersson850
Obviously it's a good thing
Gallery: 35 photos
Sep 19, 2021 11:31 |  #11
It rather seems it doesn't work at all, no matter what you want to do.
You can use a transmitter on the camera, and still set the system up using the menu system on the camera. But it does of course have to be a transmitter that's compatible with the camera's function. Like Canon's own ST-E3-RT, for example.
Anders
6,245 views & 1 like for this thread, 8 members have posted to it.
1070 guests, 114 members online
