This is my very first attempt at taking portraits. My sister-in-law was over so we were just seeing what we could do with the equipment.
I used my Digital Rebel XT with the 70-300mm lens (at the 70mm zoom). I also had 1 key light (160 Watt/sec) set at 1/2 power with a 20" x 28" softbox set on the left of the camera at an angle coming from above her. I also had the same light with softbox set at 1/8 power just slightly to the right of the camera for fill. The fill light was set higher off the ground than the key light. At this point I found it overwhelming to even consider a hair light or background light. Actually I found it slightly overwhelming just with the two lights.
I know these are not by any means perfect and I'm looking for some pointers to improve my lighting. Thanks for any help. I've already learned a tremendous amount from reading posts from others these last few weeks. Thank you all!
