Thread started 26 Jan 2014 (Sunday) 22:01
Doing a lens comparison
KirkS518
Joined Apr 2012
Jan 26, 2014 22:01 |  #1
I want to do a side-by-side comparison of IQ between two lenses. I want to compare sharpness, color, and contrast.
What would you recommend I set up to do this in the best 'almost scientific' manner?
If steroids are illegal for athletes, should PS be illegal for models?
Digital - 50D, 20D IR Conv, 9 Lenses from 8mm to 300mm
Analog - Mamiya RB67 Pro-SD, Canon A-1, Nikon F4S, YashicaMat 124G, Rollei 35S, QL17 GIII, Zeiss Ikon Ikoflex 1st Version, and and entire room full of lenses and other stuff
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Jan 26, 2014 22:22 |  #2
As long as the lenses are of a similar focal length. Shoot the same scene with the camera locked on a tripod. Ideally care would be taken to focus properly. Live view zoomed in perhaps. Make sure the scene is in good light. Take as many variables outr of the mix as possible.
vengence
Joined Mar 2013
Jan 26, 2014 22:53 |  #3
Tripod, tripod, tripod.
gasrocks
Jan 26, 2014 23:29 |  #4
Yes, tripod, MF, LiveView 5x 10x, remote switch.
Photogaz
Jan 27, 2014 01:02 as a reply to  @ gasrocks's post |  #5
As others have said, a Tripod is obviously necessary.
Just take a your time getting the right focal lengths and comparing results. I've done it before and found it does take a bit of time.
Then in Photoshop map the layers on top of each other and do your comparison there.
Photographer Hertfordshire (external link)
ceriltheblade
Jan 27, 2014 01:48 |  #6
will the comparison be at the same ISO, focal length and scene (you have to choose the scene wisely so as to look for differences - whether it be flare, high contrast situations, low contrast situations, 2d chart, 3d scene, question of mirror lock up, question of exposure of the picture and same light source....)
7D/5dIII
50 1.8 II, MP-E65, 85 II, 100 IS
8-15 FE, 10-22, 16-35 IS, 24-105, 70-200 f4IS, 100-400 ii, tamron 28-75 2.8
600 ex-rt, 055xproB/488rc2/Sirui k40x, kenko extens tubes
Bonbridge
Gallery: 20 photos
Joined Jan 2012
Jan 27, 2014 05:58 |  #7
I would use someone to put in the frame. Lots of photographers do take photo's of people. They want to see how the lens performs when shooting people (skin tone, sharpness on a person). So, I would take your gear to a location, where you can get a nice background, set your camera on the tripod. focus with manual on the person in the frame. Take the picture and put the other lens on the camera en shoot the exact same shot.
Here is an example:
http://www.youtube.com …Cg3fg&feature=c​4-overview (external link)
5DII + 6D | 16-35/4.0L IS | Σ35/1.4A | 40/2.8 | Σ85/1.4A | 70-200/2.8L IS II
iMac Retina 5k | i7 | 24Gb RAM | 512GB Flash | 4GB M295X
Website (external link) | flickr (external link) | Instagram (external link)
KirkS518
Joined Apr 2012
Jan 27, 2014 09:24 |  #8
ceriltheblade wrote in post #16640261 (external link)
Yes. Exposure will all be the same, as I'm going to do as much of a controlled environment as possible.
Things like tripod, LV, MF, etc., were a given for me. I'm more or less asking about what 'subjects' would be the best for a comparison. I'll be using an ISO 12233 chart, possibly the Kodak Q-60 chart, and this one (external link) (which is more of a printer test chart, but has color and skin tones).
As for including a person makes sense, but couldn't things like subject movement (during lens changes, breathing, natural movement) skew things a bit?
And as for ensure the duplication of FL's, what is the best way? I'm sure the scale(s) on the lenses are a great guide, but I doubt they are exact.
gonzogolf
Gallery: 561 photos
Jan 27, 2014 09:34 |  #9
Give us a hint as to which lenses you are comparing. DPreview has a still life studio scene they shoot when they test dynamic range and IQ for camera body tests. I would think a similar scene would be a fair test. Maybe place a few canned goods, some random stuff off your desk, things with some color, and some blacks, whites, etc. The point is to be able to put the shots side by side on the screen to look for differences in the output.
ceriltheblade
Jan 27, 2014 09:54 |  #10
agreed. I really like the comparison of real things in 3d for many of the concepts you mentioned you wanted to test : sharpness, contrast, and color. a human is usually problematic and won't sit still for as long as you'd like - and they have this annoying thing they do - move! :) [and some of them speak too! gasp!] :D
but I would also suggest having more than one scene
one with high contrast objects and low contrast objects as well.
in regards to the focal length - how much of a difference are the focal lengths?
7D/5dIII
KirkS518
Joined Apr 2012
Jan 27, 2014 10:04 |  #11
Focal lengths are almost identical.
gonzogolf
Gallery: 561 photos
Jan 27, 2014 10:05 |  #12
KirkS518 wrote in post #16640991 (external link)
Then dont worry about it too much.
J ­ Michael
Jan 27, 2014 10:08 |  #13
The test procedure using a USAF test chart is to place the chart at either 55 or 27 times the fl of the lens being tested. Then your chart comparisons should be pretty close. There is also an instruction to print 5 charts, one for the center and each corner. This will give you an objective resolution comparison as well as color fringing and falloff. Shoot over a range of f-stops. The metadata will track the info unless you are testing a manual focus legacy lens. Resolution isn't everything, so do some field tests under similar conditions.
eddie3dfx
Joined Sep 2009
Jan 27, 2014 12:26 |  #14
i would do it both automatic center and manual center for both lenses.
This way you can eliminate any bad focusing variables... I'd hate to find out I have a really tack sharp lens only for the automatic focus to be way off and need ma adjustment.
Also, eliminate any uv filters.
Canon 6D, Canon L 24-105, Zeiss Distagon 28mm 2.8, Planar 50mm 1.4, Planar 85mm 1.4, Sonnar 135mm 2.8 & Zeiss Mutar 2x, Canon 50mm 1.8
http://www.edwinraffph​otography.com/ (external link)
KirkS518
Joined Apr 2012
Jan 27, 2014 13:44 |  #15
eddie3dfx wrote in post #16641389 (external link)
I'll be using 10x LV and manual focus only for the test.
and what is this thing you speak of called - uv filters? :) Never on any of my lenses.
3,883 views & 0 likes for this thread, 13 members have posted to it and it is followed by 2 members.
1053 guests, 104 members online
