Thread started 26 Jan 2014 (Sunday) 22:02
Can't turn camera on
Veli
1 post
Joined Jan 2014
Jan 26, 2014 22:02 |  #1
I am a new user of a Canon EOS 550D.
The camera will not switch on at all and I wondered if this was something that happens or am I doing something wrong.
Any ideas would be appreciated.
Veli
gjl711
Jan 26, 2014 22:12 |  #2
Might check the battery first. Make sure it's charged.
Check the CF door to make sure it closes.
Outside of those two, not much else controls turning on the camera that you can get to.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
vengence
Joined Mar 2013
Jan 26, 2014 22:23 |  #3
Yep. Charged batter, closed (SD card door), and switch to on position.
rrblint
Gallery: 84 photos
Joined May 2012
Jan 26, 2014 22:39 as a reply to  @ vengence's post |  #4
Agreed. Also there is a possibility that the charger is bad and not actually charging the battery even though it appears to. Are the battery and charger new(relatively), and are they the ones that came with the camera?
Mark
tzalman
Fatal attraction.
Jan 27, 2014 06:35 |  #5
Batteries have a life span that is affected by the number of discharge/recharge cycles they have gone through. I assume you bought the camera used and you do not know its history, so the battery may have failed.
Elie / אלי
Frodge
Joined Nov 2012
Jan 27, 2014 07:05 |  #6
Make sure the battery door is closed tightly.
“It's kind of fun to do the impossible.” - Walt Disney.
Equipment: Tokina 12-24mm, Canon 40mm 2.8, Tamron 17-50 2.8 XR Di, Canon 18-55mm, Canon 50mm 1.8, Tamron 70-300VC / T3I and 60D
gjl711
Jan 27, 2014 07:08 |  #7
One question which may help isolate the problem. Did this camera work before and just stopped? The reason I ask is that if it was working before then the chance of it being a battery problem is less. Batteries tend not to catastrophically fail but to sort of fade away. If it suddenly stopped, then look at the camera door, the charger itself, or the camera.
::Gear::
John ­ from ­ PA
Joined May 2003
Jan 27, 2014 07:17 |  #8
Frodge wrote in post #16640533 (external link)
Hit the "INFO" button a few times. That cycles through various LCD screen display modes one of which is a blank screen.
Several people have mentioned making sure the battery door is properly closed without telling you "why".
Most Canon cameras have a small interlock micro switch that disables battery power to the camera if the battery door is opened. It is there to keep us from swapping batteries while the power switch is on; this is called hot swapping. Look very closely at the battery compartment door for a small protrusion that goes into a small hole when the door is properly closed. Obviously if that protrusion is missing the camera thinks the battery is removed and will not power up.
There may also be a small switch in similar manner in the door that covers the SD memory card slot. If it is present check for a protrusion there as well.
One last thing, are you using a grip? If so remove it and try the camera without the grip.
830 views & 0 likes for this thread, 7 members have posted to it.
2472 guests, 94 members online
