gonzogolf wrote in post #16642365
The flashes need to communicate with the camera and its unlikely that anyone would build that capacity into a non ettl flash. If you don't want ettl you are spending a lot extra for triggers and flashes just for remote control.
You are the man Gonzo, but don't underestimate the convience and luxury of using the in camera menu to control flash power when using OCF. While I certainly use ETTL when the situation calls for it, I also use manual flash quite often. I have the 622's and yn-565ex (ETTL yes, HSS no). Having to walk over to the flash to change settings, or even worse, having to lower a stand when the flash is up higher than I can easily see (i.e. over 6ft up in the air) is a pain. Using in menu control is VERY nice in these situations. The 565ex is about 100 bucks and 622's are 65ish. IMO, worth every penny even if I never used ETTL. Just my two cents.
