Thread started 28 Jan 2014 (Tuesday) 04:19
5D3 + 50mm 1.4: best aperture for manual focusing on eyes?
thedcmule2
Joined Nov 2011
Jan 28, 2014 04:19 |  #1
Now I know the 5d3 is a autofocus king in its own but there are times when im shooting portraits that force me to slow down, choose an AF point, choose another AF point because I recomposed a little, hit the back-button AF and then push the shutter...which by then the magic moment is gone, but the eyes are tack sharp. I generally shoot at f/2.0-2.8, and when I manually focus I feel like photography is so much easier, faster and more fun...but the downside is my focus rarely nails the eyes when doing so (though in the viewfinder it appears otherwise).
I feel somewhat more connected and fluid when manual focusing, I can talk to the subject without having to think too hard on whether or not im choosing the right AF point and lining it up properly which causes awkward silences...does this sound like crazy talk? Anyone experience this anxiety before and have any tips? I am thinking maybe I should stop down to f/4 for manual focusing but I don't know if thats the best move...
titi_67207
Jan 28, 2014 04:49 |  #2
Use live-view maybe ?
Canon 5D MkII + Sony A7 + 24x36 & 6x6 B&W film cameras .
CV 15 4.5 III | TS-E 24L II | FE 28 2 | (50+85) 1.4 | 135 2 | 70-200 4.0L | a collection of old Zuikos + FD + Adaptall + AI-s + M42
gasrocks
Jan 28, 2014 07:42 |  #3
Make sure your eyepiece (diopter) is adjusted correctly. MF will be off if it is't. Also, check it often as it can easily be bumped/changed. In A/V mode you are focusing using f/1.4 - which is the most precise.
vengence
Joined Mar 2013
Jan 28, 2014 09:43 |  #4
Look into focus screens. If you want to nail manual focus, they're what you need.
msowsun
"approx 8mm"
Gallery: 18 photos
Jan 28, 2014 11:59 |  #5
The 5D3 comes equipped with the best focus screen possible..... 10X Liveview ;)
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Jan 28, 2014 12:30 |  #6
thedcmule2 wrote in post #16643375 (external link)
Heya,
When focusing, it's going to use the widest aperture, up to F2.8 during the focusing. Then once you press the shutter release, and expose, it will change aperture to whatever you set it to, be it up or down. So you're already using F2.8 in your case, during focusing.
For capturing eyes, it's hard to do it at F1.4. They have to be in the same plane. The only way to do it, easily, at F1.4 is going to be from a distance, like doing an upper body bust/portrait, or full body with environment. If you try to do a full face portrait and focus on eyes then recompose, you may find only one eye getting into focus unless they are literally flat, eyes wise, towards your lens. The closer you are to them, the thinner the depth of field, the more difficult to get both eyes in focus. The more you stop down the aperture, the more depth of field, so if you front focus on eyelashes or nose, the eyes will be in focus regardless, when stopped down. F4 is a "safe" aperture, so to speak, because you will most likely get everything in focus while still having a blurry background (if there's even a background to see).
The 50mm F1.4 (Canon) is softish at F1.4. So stopping down to F2.0 or F2.8 is good. Granted, that's 1 and 2 full stops of depth of field loss/gain, depending on how you look at it, and kind of raises the question of why even bother having the 50 F1.4 anyways.
If you're looking to do manual stuff, there are sharper lenses that have F1.4 if you're interested.
Have you thought about going to an 85mm?
Very best,
vengence
Joined Mar 2013
Jan 28, 2014 13:49 |  #7
msowsun wrote in post #16644352 (external link)
I live view focus all the time, from a tripod. It's a pain in the ass otherwise.
smorter
Jan 28, 2014 18:25 |  #8
+1
My 24LII is unreliable AF wise and I always use liveview for portraits
Wedding Photography Melbourneexternal link
Reviews: 85LII
KirkS518
Joined Apr 2012
Jan 28, 2014 18:29 as a reply to  @ smorter's post |  #9
Maybe I'm confused, but isn't the lens wide open during focusing, so you're focusing at f/1.4? Unless you're trying to focus while using DOF preview, there is no 'best aperture for manual focus'.
Someone correct me if I'm wrong (I have faith that if I am wrong, I will quickly be corrected!). :)
If steroids are illegal for athletes, should PS be illegal for models?
Digital - 50D, 20D IR Conv, 9 Lenses from 8mm to 300mm
Analog - Mamiya RB67 Pro-SD, Canon A-1, Nikon F4S, YashicaMat 124G, Rollei 35S, QL17 GIII, Zeiss Ikon Ikoflex 1st Version, and and entire room full of lenses and other stuff
MalVeauX
Joined Feb 2013
Jan 28, 2014 18:36 |  #10
KirkS518 wrote in post #16645407 (external link)
Heya,
I think it stops at F2.8 for autofocus?
Very best,
KirkS518
Joined Apr 2012
Jan 28, 2014 18:46 |  #11
Are you saying it is stopped down to f/2-2.8 when it's mounted, and if f/1.4 is selected to take the shot, it opens up? I didn't have the lens long enough to notice if that's what it did. It's also the first time I've heard of a lens that operates that way. ???
msowsun
"approx 8mm"
Gallery: 18 photos
Jan 28, 2014 19:02 |  #12
MalVeauX wrote in post #16645424 (external link)
Heya,
Very best,
No, Auto Focus and Metering are always done wide open.
jmikolich
Joined Feb 2013
Jan 28, 2014 19:02 |  #13
I believe it to be done at Wide Open for all focusing
-Jim
Canon 5D3,5D3,5D2,6D,24 f2.8 IS,35L,45 TS-E,50L,85 f1.8,70-200 f2.8L II,100L
Rokinon 14mm f2.8
Aronis
Joined Jan 2014
Jan 28, 2014 19:57 |  #14
Using live view at 10x to focus makes it hard to quickly focus AND compose, does it not??
1Dx, 10D 28-70 L 2.8, 70-200 L 2.8 III, 50 1.4, 28 2.8
InfiniteDivide
"I wish to be spared"
Gallery: 265 photos
Joined Dec 2013
Jan 28, 2014 22:16 |  #15
I have the 6D and find that AI Servio with the 50 1.4 works well.
While on a tripod, even a slight movement is corrected.
While manual focusing is great, and 10x live view is the best.
For human portraits it can be a pain to refocus from a little change at 10x
I don't find 10x useful unless I am doing product shots on inanimate objects.
For me, a fast shutter and AI Servio work well for the slight changes at 1.4
Perhaps my friends need less caffeine and more patients in their lives.
I am not trying to create a photo studio either. Just some nice portraits at 1.4-2.0 for them.
James Patrus
6D | 16-35L F4 | 24L II | 50L | 100L | |  -> Website (external link) & Gallery (external link)
Do you enjoy Super Famicom games? (external link)
4,469 views & 0 likes for this thread, 12 members have posted to it.
1345 guests, 176 members online
