Thread started 28 Jan 2014 (Tuesday) 18:59
files disappearing from SD card
zedvictor1
Joined Jan 2014
Jan 28, 2014 18:59 |  #1
I took a few dozen shots with my 60D, looked at a few frames on the camera's screen and then set the camera down. Later, when I inserted the SanDisk Extreme 16GB card into my computer, not one of the files was there. Earlier files were still on the card, but the last few dozen had vanished.
Can anyone suggest what stupid thing I could have done? Nothing like this has ever happened to me before, and I certainly don't want it to happen again.
Thanks.
DwainRowe
Joined Mar 2011
Jan 28, 2014 19:07 |  #2
Did you look in every subfolder? My cameras are set to begin a new folder when a certain file number is reached.
6D | 6D Mk II | 7D | 7D MK II | EF 17-40 f/4 L | EF 70-200 f/4 L IS | EF 50mm f1.4 USM -|- Rebel T2i | EF-S 17-55 IS | Σ 10-20 f3.5 EX DC | Σ 70-300 4-5.6 DG Macro (Yes, I am cheap) | Speedlite 580EXII | YN622c
EOS M | EFM 22 f/2
zedvictor1
Joined Jan 2014
Jan 28, 2014 19:09 |  #3
Thanks. Yes, unfortunately, I did look in subfolders.
rrblint
Gallery: 84 photos
Joined May 2012
Jan 28, 2014 19:33 as a reply to  @ zedvictor1's post |  #4
Try putting the card back in the camera and see if the new pics can still be seen on the camera's LCD.
Mark
zedvictor1
Joined Jan 2014
Jan 28, 2014 21:51 |  #5
No, I can't see them on the camera although I could initially which makes me think they were on the card at one point.
spear
Jan 28, 2014 23:40 as a reply to  @ zedvictor1's post |  #6
Do a test to see if your card is not counterfeit. I recommend you download and test your card using the utility on this page
http://sosfakeflash.wo​rdpress.com …g-usb-counterfeit-drives/ (external link)
The way card memory works is that sometimes on a bad batch a 32gb card will not be discarded but will be remapped as a 16gb and sold cheap to someone. Unfortunately that someone can be unscrupulous and remap it again at 32gb. The header on the card will s how 32gb and it will format normally and will seem fine until you save something on the corrupt part of the memory. It is quite surprising how many counterfeit cards are out there and sometimes even from reputable sellers that also got duped. It is a good idea to test every card you have to make sure it is good ... nothing worse than taking some memorable shots only to find out they are not on your card when you get home! All counterfeit cards I ended up with were bought from Ebay, some of those sellers had stellar reputations. My recommendation is to pay more and buy from one of the good reputable shops (Adorama etc...). If the price seems too good to pass up then chances are it is fake ... or at least don't consider you got a good deal until you run the card through the utility.
Canon 40D, 5DII, 5DIII, G9,G11,S100,G1X, Canon lenses 600mmL f/4 ,24mm-105L f/4, 16-35L II f/2.8, 70-200L II f/2.8, EF 100mm f/2.8, EF 50 f/1.4,17-85 EFS, 10-22 EFS, 580 EX, 2x 580 EXII, 270EX,STE2, 1. 4x Converter, 2.0x Converter. Nikon 800E w/Nikkor 24-70
zedvictor1
Joined Jan 2014
Jan 29, 2014 00:00 |  #7
Thank-you for the information about counterfeit cards.
What baffles me is that I played back some of the images 5 minutes after I had taken them. Now, only that batch of images is gone. The whole batch. It makes sense to think I'm missing part of the story, but the card did not leave the camera between when I took the pictures and when I inserted it into my computer. I keep hoping for an epiphany, but nothing's coming.
InfiniteDivide
"I wish to be spared"
Gallery: 265 photos
Joined Dec 2013
Jan 29, 2014 00:28 |  #8
^ could it be a utility on the post processing software wipe it each time?
EI "format images after import" box is checked?
I know my Iphone ALWAYS asks if I want to Delete imported photos and I keep says NO...
James Patrus
6D | 16-35L F4 | 24L II | 50L | 100L | |  -> Website (external link) & Gallery (external link)
Do you enjoy Super Famicom games? (external link)
Gregg.Siam
Joined Jun 2010
Jan 29, 2014 01:33 as a reply to  @ InfiniteDivide's post |  #9
No reason why other than the above or possibly a bad sector, but just use Photorec to recover the images. If it's a bad sector you might be out of luck, but you can try.
http://www.cgsecurity.​org/wiki/PhotoRec (external link)
5D MKIII | 24-105mm f/4 L| 50mm f/1.8 | 600EX-RT [FONT=Tahoma][COLOR=bl​ue][FONT="]|
∞ 500px (external link)
1,539 views & 0 likes for this thread, 6 members have posted to it.
2472 guests, 94 members online
