Tinncupp wrote in post #16647724
Hi,
As the title suggests, I'm a new novice photographer. I've got a Canon EOS Rebel T3i. I primarily am using the camera at the moment for day to day photography (family events, childrens activities, etc.). My daughter is a competitive ice skater and the lens that came with the camera EF-S 18-55M does not capture a wide enough area for me to film/photograph skating competitions. As such, I am looking for recommendations for a lens that will enable me to capture a much wider area and am looking to stay around $300 if possible for the lens. I'd really appreciate any recommendations from the experts in this forum. Also, I am wondering is there such as a thing as a wide angle - zoom lens? If so, would that be a better way to go so I could go from close up at a distance to wide angle without switching lenses? Thanks in advance for any advice!
Cheers,
Tinncupp
Heya,
Wider, with a zoom section that takes you "close" unfortunate doesn't exist. It's either ultrawide, or it's a mid-zoom, like you have. And ultrawide zooms, are not happening for you at $300. Especially not something that does smooth perfect video focus, like an STM lens (as none of them are wide enough for what you're doing).
Ultrawide on a crop, below that 18mm, will happen at 10mm, 11-16mm and 14mm basically.
You can get 18-XXX lenses, or 17-XXX lenses. But getting wider than that, you start to see a big drop in the long end, to absolute non-existence of the long end, so you're not going to find a 10~200mm for example, as it just doesn't exist. Especially with fast aperture for the lighting of a skate rink.
Solution (costly, but will work):
Two camera bodies.
One with ultrawide -> wide (get a cheap used old body that is crop factor, or even full frame, whatever you want, and a really wide lens or wide zoom)
One with mid-telephoto zoom (50~70 to 200~300mm)
Drop & Swap to the other body as needed.
Very best,
