Thread started 02 Feb 2014 (Sunday) 12:02
EF 28-105 went swimming
hroonk55
1 post
Joined Feb 2014
Feb 02, 2014 12:02 |  #1
Dunked my rig in 3 feet of water yesterday. I can see water inside lens and water spots on the inside of the main glass where 2 drops dried.
Is there any fixing this or should I just order a new one?
EF 28-105mm 1:3.5-4.5 II USM
gjl711
Feb 02, 2014 12:19 |  #2
Well, if your really adventurous you can take the thing apart and try and clean it but odds are that the lens is dead. Canon will not fix it.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
davidfarina
Gallery: 43 photos
Joined May 2013
Feb 02, 2014 12:49 |  #3
Put it in a dryer or a drying box, last chance id say
Sony A7RII | Sony A7S
EF 40 | EF 70-300L | FD 35 Tilt-Shift
FE 16-35 | FE 28 | FE 90
CV 15 4.5 III | CV 40 1.4 MC | Summilux 50 ASPH
Website (external link) | 500px (external link)
EOS5DC
Joined Dec 2013
Feb 02, 2014 14:09 |  #4
Whoa! Sorry about that. That is one of the few older lenses I regret selling. I'd drop it in a bowl of rice, put the lid on, and wait a week. My guess is that it is dead, though.
Bodies: 60D, 6D.
EFs: 15-85, 10-22
EF: 28-75, 35 f/2 IS, Σ70-200 OS, 100-400L
Flash: 580EX II, 430 EX II
Sibil
Feb 03, 2014 07:27 as a reply to  @ EOS5DC's post |  #5
Find a local repair shop that'll fix it at a lower labor rate, than Canon. Or, look for a used one. The lens should be taken apart and cleaned as the dried water spots will leave marks on the elements.
eddie3dfx
Joined Sep 2009
Feb 03, 2014 07:32 |  #6
There might be a chance. Dry it and then put in a bag with rice.
Even if the lens miraculously works, the glass with be dirty... but to answer your question, yes water doesn't necessarily mean broken..
Canon 6D, Canon L 24-105, Zeiss Distagon 28mm 2.8, Planar 50mm 1.4, Planar 85mm 1.4, Sonnar 135mm 2.8 & Zeiss Mutar 2x, Canon 50mm 1.8
http://www.edwinraffph​otography.com/ (external link)
phreeky
Feb 03, 2014 07:41 |  #7
There is no way a box of rice or similar will do a thing on its own - you'd need to strip it down if you can see water inside. Even then I give the USM unit next to no chance, and the aperture not much more.
John ­ from ­ PA
Joined May 2003
Feb 03, 2014 12:47 |  #8
Those things depending on the version can be had quite inexpensively on eBay. The 2nd version, the one with "macro" on the barrel instead of the flower icon, is virtually the same as the "II". See http://www.ebay.com …enses&hash=item​35d165b43f (external link)
John ­ from ­ PA
Joined May 2003
Feb 03, 2014 12:50 |  #9
Explanation of versions at http://www.ebay.com …/10000000000771​280/g.html (external link)
Christopherm
Gallery: 105 photos
Joined Dec 2011
Feb 03, 2014 12:53 |  #10
I'd recommend giving it a bath in distilled water before completely giving up on it.
Gear: A lot more than I deserve and a lot less than I want!
John ­ from ­ PA
Joined May 2003
Feb 03, 2014 14:13 |  #11
Christopherm wrote in post #16660514 (external link)
This will cost you $2 and likely has as much a chance of working as making a silk purse out of a sows ear.
gjl711
Feb 03, 2014 14:15 |  #12
Even if you dunk it into distilled water to neutralize the salts and such, you are still going to have to take it apart to clean and lubricate everything. This is not an easy undertaking but can be done.
::Gear::
EOS5DC
Joined Dec 2013
Feb 03, 2014 18:04 |  #13
A bath in 95% EtOH would be better. Water isn't going to dry up water.
Bodies: 60D, 6D.
EFs: 15-85, 10-22
Nick ­ Aufiero
Gallery: 6 photos
Joined May 2013
Feb 03, 2014 18:45 |  #14
Alcohol bath will push out the water.
gjl711
Feb 03, 2014 19:09 |  #15
Nick Aufiero wrote in post #16661333 (external link)
It will also dissolve any lubricant inside and spread it over the optics.
::Gear::
2,312 views & 0 likes for this thread, 11 members have posted to it.
1918 guests, 101 members online
