The only way I can see to access the flash compensation is to go into the menu and scroll down through the settings to adjust it , is there a short cut or quicker way to do this process?
tongard Senior Member More info | Feb 02, 2014 12:26 | #1 The only way I can see to access the flash compensation is to go into the menu and scroll down through the settings to adjust it , is there a short cut or quicker way to do this process? Canon 6d, 7d2.
Madwrench Senior Member 633 posts Likes: 9 Joined Feb 2011 More info | Feb 04, 2014 07:31 | #2 tongard wrote in post #16658018 The only way I can see to access the flash compensation is to go into the menu and scroll down through the settings to adjust it , is there a short cut or quicker way to do this process? You can adjust FEC from the same screen you turn the flash on/off in (right side of the rocker switch, flash icon).
wcameron Senior Member 527 posts Gallery: 4 photos Likes: 9 Joined Mar 2006 Location: Canmore, AB, Canada - The Heart of the Rockies More info | Mar 03, 2014 23:24 | #3 I set up the custom ring to do exposure compensation. When using the flash, all i have to do is hit the flash button once and then I can use the dial to turn FEC up and down as much as needed (at least the +2 or -2 limits). Ward
| Latest registered member is Niagara Wedding Photographer 1431 guests, 146 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
