Thread started 03 Feb 2014 (Monday) 03:55
Panning
Northwoods ­ Bill
Joined Jun 2012
Feb 03, 2014 03:55 |  #1
So I got a chance to shoot the snow mobile race this weekend. Pretty happy with the results. Most everything I took were still shots but fortunately the snow kicking up and the snow dust give somewhat of a sense of speed. I was trying to pan on some shots but I was having trouble getting my shutter down enough. I was using a 70-200 f2.8, shooting wide open with an ISO of 100 and still my shutter speed was holding at around 320. So should I have closed down on the aperature some even though it would increase my DOF or should I have gone to a ND filter? Curious what others have done? My concern with the ND filter is if it would slow down autofocus? Shooting with a 5d3
Thanks!
Bill R
Web:https://www.flickr.com​/photos/whitebirch/ (external link)
JeremyKPhoto
Joined Apr 2012
Feb 03, 2014 04:13 |  #2
Even if you increase your DOF by stopping down, the panning will create a lot of blur so it wont matter as much (from my experience)
5D Mark III / 70-200 2.8L IS II / 24-105L / 50 1.8 stm / Tamron 70-300 VC / Sigma 85mm 1.4 Art
Hibino
Joined Dec 2011
Feb 03, 2014 04:29 |  #3
I'm no expert but I always shoot shutter priority. If it's too bright I'll chuck an ND filter on and have never had an issue with autofocus on my 7D
7D | Tamron 24-70 ƒ/2.8 | 70-200mm ƒ/2.8L IS II | Sigma 35mm ƒ/1.4 | Tokina 11-16mm ƒ/2.8 | 430EX II | YN-568EX II
Northwoods ­ Bill
Joined Jun 2012
Feb 03, 2014 04:39 |  #4
OK. Thanks guys.
Not sure when I will have a chance to try again, but I will be on the lookout!
I am just starting to go through everything (shot for almost four hours straight) but here is one of the stills that I got.
IMAGE: http://farm3.staticflickr.com/2861/12285274613_5b301ffde3_b.jpg
IMAGE LINK: http://www.flickr.com …hwoods_photo/12​285274613/  (external link)
Bill R
DC ­ Fan
Feb 03, 2014 08:13 |  #5
Northwoods Bill wrote in post #16659590 (external link)
Thanks!
Slow shutter speed panning images with a 70-200mm f/2.8 lens.
IMAGE: http://i1174.photobucket.com/albums/r601/kevinlillard/02032014c/2013-08-09a-0193_zpsa06a4fe7.jpg
Camera Maker: Canon
Camera Model: Canon EOS 5D
Lens: EF70-200mm f/2.8L IS USM
Image Date: 2013-08-09 17:40:15 (no TZ)
Focal Length: 105.0mm
Aperture: f/29.0
Exposure Time: 0.010 s (1/100)
ISO equiv: 400
Exposure Bias: none
Metering Mode: Unknown
Exposure: shutter priority (semi-auto)
White Balance: Auto
Flash Fired: No (enforced)
Orientation: Normal
Color Space: sRGB
IMAGE: http://i1174.photobucket.com/albums/r601/kevinlillard/02032014c/2013-09-21a-0120_zps883ded31.jpg
Camera Maker: Canon
Image Date: 2013-09-21 17:47:30 (no TZ)
Focal Length: 110.0mm
Aperture: f/32.0
Exposure Time: 0.017 s (1/60)
ISO equiv: 800
Exposure Bias: none
Metering Mode: Matrix
White Balance: Auto
Orientation: Normal
Color Space: sRGB
GPS Coordinate: undefined, undefined
IMAGE: http://i1174.photobucket.com/albums/r601/kevinlillard/02032014c/2013-08-09a-0211_zps19ae827c.jpg
Camera Maker: Canon
Image Date: 2013-08-09 17:40:52 (no TZ)
Focal Length: 130.0mm
Aperture: f/20.0
ISO equiv: 400
Exposure Bias: none
White Balance: Auto
Orientation: Normal
Color Space: sRGB
The technical camera setting key is to use the camera's shutter priority mode (T or TV for Time Value). Choose the shutter speed and the camera will automatically calculate other exposure settings.
A slow shutter speed will, as in all situations, allow more light into a frame. That will require a smaller aperture for a correct exposure.
Some photographers will select a large aperture for a shallow depth of field. That is not necessary for panning images, where motion blur will result from the slow shutter speed and isolate the subject.
Also, the slow shutter speed panning technique benefits from a cluttered background, which when blurred, enhances the illusion of motion.
lusospeed
Joined Dec 2012
Feb 03, 2014 22:41 |  #6
Thanks!
With the 5DmkIII you don't need to shoot at 100 ISO. By increasing your ISO to around 400, it will allow you more depth of field. Also mentioned, if you're panning, set the camera to shutter priority. Also, one of the tools that some use when panning, is to use a monopod and track your subject with the camera mounted on one. The one thing that will happen as you go lower with your shutter speed, the number of useable images tends to decrease.
http://www.lusospeed.c​om (external link)
pixelbasher
Feb 04, 2014 02:38 |  #7
Why recommend shooting at higher ISO when he is trying to slow the shutter down? Unless you like shooting at F/infinate ;)
Use the lowest ISO you can and simply set a shutter speed you want and let aperture take care of itself in (Tv mode) If it's still too bright throw an ND filter on it.
DC fan: Why use ISO 800 then run it at F/32 for your second pic ?
Aperture: f/32.0
ISO equiv: 800
Why not shoot at ISO 100 and get your aperture around F/11 instead? It was obviously a bright day yet all your shots seem to be at relatively high ISO for what it was you were after, which was slow shutter pans. You certainly didn't need the DOF of F/32 for that shot, and if you did it would have been blurred anyway. ;)
50D. 7D. 24-105L. 100-400L. 135L. 50 1.8 Sigma 8-16
flickr
DC ­ Fan
Feb 04, 2014 08:02 |  #8
pixelbasher wrote in post #16662090 (external link)
Aperture: f/32.0
ISO equiv: 800
It's a conspiracy. :)
Actually, when I was playing with camera settings, I missed by a couple of detents on the control wheel. The interesting point is that the ISO settings didn't make any difference in the actual pictures. Shutter speeds were all that counted.
And, as already noted, in shutter priority, the camera body automatically chooses the aperture. From the look of the images, there was no damage done.
pixelbasher
Feb 05, 2014 01:30 |  #9
DC Fan wrote in post #16662393 (external link)
says the full frame shooter ;) :lol:
flickr
lusospeed
Joined Dec 2012
Feb 08, 2014 01:34 |  #10
The point of shooting at a higher ISO is that it increases your DOF. While a higher ISO will allow more light in, you can usually reduce that with a polarizer. Suggesting that you lower the ISO will only lessen the DOF. Shooting a moving object at f2.8 will yield nearly useless photos when the object is in motion and the shutter speed drops. You simply will not get consistent results with a shallow depth of field and a fast moving object. If you bump up the ISO, and then either use a polarizer, or an ND filter to block out some of the light, by virtue of the higher DOF, anything you place in front of that lens to block light will lessen the DOF, BUT will not be as severe as just lowering the ISO. The OP is also shooting in an environment where there is a vast amount of snow. Do you expose for the snow, or the moving object?
pixelbasher
Feb 08, 2014 02:09 |  #11
I'm not suggesting he lowers it, he was at 100, I'm suggesting ramping up to 800 then having to stop down to F32 makes no sense. Does he even need to increase the DOF? in fact in the OP comment he was worried about increasing the DOF. If he wants to shoot at 2.8 for his required DOF, and wants to slow it down from his 1/320 he was at, the an ND of your choice is the way to go.
When you are panning like the car shots above all you need is enough to cover the subject and a bit more to reduce the chance of a misfocus due to it being quite thin......that's it, you don't need 3 miles of DOF to pan a car or a snowmobile side on in 99% of situations, unless you are at 200mm and standing 10 ft from it.
One stop on the shutter down to 1/160, one stop of the aperture to F/4 and he's away. If he wants to slow it down even more do it again, 1/80 @ F/5.6 Why shoot at the noisy end of the sensor and the most diffracted end of the lens when you can achieve the same exposure and get the type of shot you want simply using more "sweet spot" settings?
That's the bit I don't get. I understand it achieves more DOF, BUT that's NOT what he asked for. ;)
flickr
3,664 views & 0 likes for this thread, 6 members have posted to it.
Panning
1293 guests, 136 members online
