Thread started 03 Feb 2014 (Monday) 09:58
struggling with 1 FF body at a wedding
Nick_Reading.UK
Joined Nov 2011
Feb 03, 2014 09:58 |  #1
I am a newbie to weddings.. did one the other day and Shoot went well but......
after shooting the registry office wedding with my 70-200 I had to change lens to my 50mm for outside shots (Would have been better if I had a 24-70 2.8). While I was doing this everyone was pilling outside ready for them walking out and being showered with confetti. I just got outside in time to catch it, but literally within seconds.. so all was good..
That was a very close call, I am sure I need two bodies (like wedding Photographers do).. One with the 70-200 and the other with a 24-70 2.8 or a prime.
I will be doing more weddings in future...
Has anyone else experienced the same sort of thing.. ?? or anyone got any advise or agree or disagree??
Nick :)
EOS 5Dmk3 X2, 60D, EF24-70mm f2.8L mk2, EF70-200mm f2.8L IS mk2, EF85mm f1.8, EF50mm f1.4, EF50mm f1.8 mk1(350D with 18-55mm Sh"kit" lens).
Speedlite 600EX-RT, 430EX II Flash. manfrotto 190XDB tripod, Giottos GTMML 3290B Monopod, B+W 77mm 110 Single Coated filter, Hama 77mm Variable Neutral Density Filter.
Charlie
Guess What! I'm Pregnant!
Feb 03, 2014 10:08 |  #2
2 bodies + optech dual harness.
Sony A7riii/A9 - FE 12-24/4 - FE 24-240 - CV 21/3.5 - FE 28/2 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - EF 135/1.8 Art - F 600/5.6 - CZ 100-300 - Astro Rok 14/2.8 - Tamron 28-75/2.8 RXD, 70-200/2.8 VC
BrickR
Joined Mar 2011
Feb 03, 2014 12:05 |  #3
I always carry 2 bodies if I'm in a situation where I want different lengths. Long lens on one, short lens on another. Makes life tons easier....as you have experienced ;)
I have a double sling but I lost interest in it because every time I bent over, or turned, or did anything quickly I had to worry about the cameras swinging around. Bending down to get something out of a case is a hassle; gravity wants to pull the cameras straight down, perpendicular to the floor where they are in the way, not parallel to your body where they are out of the way.
So I got a B Grip and keep one camera on my waist (turned behind me to be out of the way) and the other camera on an Optech sling.
So yes, keep 2 cameras on you :)
My junk
The grass isn't greener on the other side, it's green where you water it.
gonzogolf
dumb remark memorialized
Gallery: 18 photos
Feb 03, 2014 12:07 |  #4
Two bodies are a must for weddings if for no other reason than insurance against failure. That said, one with a longer lens, one with a wider lens is the usual deployment.
Numenorean
Feb 03, 2014 12:08 |  #5
I typically have the 5DII with 70-200 and the 7D with 17-55. I have a black rapid dual strap to carry them and pocket wizards on both so I can adjust any remote lighting on either if I need to.
Rocky ­ Rhode
Joined Apr 2011
Feb 03, 2014 12:12 as a reply to  @ Numenorean's post |  #6
I carry two bodies, several spare speedlights, batteries, ect.
Everything is redundant because you cannot predict when something may go wrong, and you can NEVER get that moment you missed back.
GEAR LIST Flickr (external link)
Left ­ Handed ­ Brisket
Gallery: 12 photos
Joined Jun 2011
Feb 03, 2014 12:27 as a reply to  @ Rocky Rhode's post |  #7
two cameras, most definitely
two FF cameras, not necessary. Your 60D would have done just fine outside, assuming it was daytime.
rang
Feb 03, 2014 12:28 |  #8
Nick_Reading.UK wrote in post #16660104 (external link)
Nick :)
I've used a Cotton Carrier for years now and always shoot a minimum of two bodies at weddings usually and sometimes three bodies depending on what is called for based on meeting discussions and shot lists.
Either two crops together or two FF's together for core. Having glass ranges but f/2.8 for all zooms for both types or bodies helps but most folks don't collect full ranges and speeds (from ultra-wide thru telezoom to 200 or beyond plus fast primes) just in case that grips will carry. So I would pick which sensor size you prefer. The reason I don't mix crop and FF is because my minds eye finds it easier to visualize the scene and how much I can capture with how much bokeh - quickly - based on the lenses in the same format. So like most here mention; one rig is wide and one rig is longer. In my minds eye I know how much compression and scene I will have in the composition when I fast swap for a different look.
I may wear and use a third rig on another side holster with a specialty lens like a fish or ultrawide and/or an IR converted body.
One key thing I found really helpful is common menu structure and models. I've memorized the effect of the customs settings I use. So although between the three bodies there will be subtle differences I know what they are and even though they are saved on each camera's Custom modes I can quickly run directly to the setting I want to change. I found it harder to change configurations when the menu structures were different.
Lotsa stuff, running outta room and a wife...I keep looking at her and wondering??? :lol:
Nick_Reading.UK
Joined Nov 2011
Feb 03, 2014 15:45 |  #9
Cheers everyone.. Some really GREAT tips/feedback !! bw!
DisrupTer911
Feb 03, 2014 15:51 |  #10
if you only have money for 1 body now, you need a quick changing lens system. like a thinktank belt and lens holder to facilitate quicker and idealy, SAFER, changes on the fly.
it'll be cheaper then shelling out for a second body when you don't have the income to support it.
can even find some used on Fred miranda or here too
www.vividemotionphotograph​y.comexternal link
Nick_Reading.UK
Joined Nov 2011
Feb 03, 2014 16:39 |  #11
I also need a quicker flash, the recycle time of my 430 Is a nightmare!! Thinking of getting a 600RT
Nick_Reading.UK
Joined Nov 2011
Feb 03, 2014 16:43 |  #12
rang wrote in post #16660446 (external link)
I agree, two of the same bodies would be better, I now struggle with my 60D menu..
Rocky ­ Rhode
Joined Apr 2011
Feb 03, 2014 17:11 |  #13
Nick_Reading.UK wrote in post #16661050 (external link)
If you have a bunch of spare cash sure; I use a couple of YN 565 II and a YN 568 II along with my 600 watt strobe in a Beauty Dish, and/or softbox all controlled by YN 622c's. Wedding is all about run & gun where ETTL is very necessary as the lighting conditions are continually changing. The Strobe is used for the big group shots where I need power.
Eventually you will want another 5d III but your 60D is more then capable with the 17-55 mounted for your second.
mattertea
Joined Dec 2012
Feb 03, 2014 17:17 |  #14
Why can't you use your 60d at a wedding as a second body with a wider lens on it?
edit- someone already said that lol.
Does anyone even consider a mirrorless camera for a second body?
Sculpting Blog (external link)
MalVeauX
"Looks rough and well used"
Gallery: 1633 photos
Joined Feb 2013
Feb 04, 2014 14:14 |  #15
Nick :)
Heya,
I've yet to see an event shooter with a single camera really. I'd take two camera bodies. Heavy and bulky, but it will do the job you need.
Very best,
2,605 views & 0 likes for this thread
Latest registered member is lesioc
875 guests, 328 members online
