Lately I've been experimenting with running manual mode but auto iso. What's the highest you would let this go for the 60D?
Stiggyiggy Member 75 posts Likes: 2 Joined Oct 2013 Location: Seattle, WA More info | Feb 05, 2014 00:40 | #1 Lately I've been experimenting with running manual mode but auto iso. What's the highest you would let this go for the 60D? Canon 60D | 10D | 17-50 f/2.8 XR | 70-200 f/4L | 75-300 f/4.0-5.6 III | 50 f/1.8 |
Feb 05, 2014 01:30 | #2 I don't go beyond 3200. Canon 80D, Canon 100-400L, EF 50 II
apersson850 Cream of the Crop More info | There's never any fixed limit like that. As high as needed to avoid motion blur, if that's what you are risking. Anders
EOS5DC Senior Member 791 posts Joined Dec 2013 More info | Feb 05, 2014 04:06 | #4 Permanent banManual mode and auto-ISO is a bad combination. You have no access to any kind of EC. The 60D, and I suspect most Canon bodies, should be dialed in for about +2/3 EC under normal circumstances. The setup you are contemplating will result in slightly underexposed, noisier than necessary photos, especially in the over 800 ISO range. Bodies: 60D, 6D.
Feb 05, 2014 04:41 | #5 Never tried beyond 3200...must give it a shot. Canon 80D, Canon 100-400L, EF 50 II
Feb 05, 2014 04:48 | #6 Stiggyiggy wrote in post #16664656 Lately I've been experimenting with running manual mode but auto iso. What's the highest you would let this go for the 60D? ISO 6400, but I use noise reduction software Run a noise reduction program and there's no more reason to worry.
Feb 05, 2014 07:34 | #7 I have set the 60D at ISO6400. I can NR ISO12800 but I want to make the decision myself. I have to say though that I haven't used autoISO in a long time. Gerry
Feb 05, 2014 10:47 | #8 Thanks for the advice everyone. Just experimenting and learning to use this thing. Canon 60D | 10D | 17-50 f/2.8 XR | 70-200 f/4L | 75-300 f/4.0-5.6 III | 50 f/1.8 |
pwm2 "Sorry for being a noob" 8,626 posts Likes: 3 Joined May 2007 Location: Sweden More info | Feb 05, 2014 10:57 | #9 Remember that high ISO isn't just a question of acceptable noise levels. It's also a question of loss of dynamic range, i.e. amount of details in the shadows. 5DMk2 + BG-E6 | 40D + BG-E2N | 350D + BG-E3 + RC-1 | Elan 7E | Minolta Dimage 7U | (Gear thread)
MalVeauX "Looks rough and well used" More info | Feb 05, 2014 11:42 | #10 Stiggyiggy wrote in post #16664656 Lately I've been experimenting with running manual mode but auto iso. What's the highest you would let this go for the 60D? Heya,
watt100 Cream of the Crop 14,021 posts Likes: 34 Joined Jun 2008 More info | Feb 05, 2014 12:22 | #11 Stiggyiggy wrote in post #16664656 Lately I've been experimenting with running manual mode but auto iso. What's the highest you would let this go for the 60D? I shoot at ISO 6400 but then apply some noise reduction (selectively)
Feb 05, 2014 12:32 | #12 This is interesting! How do you apply the NR selectively? Through mask? Gerry
EOS5DC Senior Member 791 posts Joined Dec 2013 More info | Feb 05, 2014 15:25 | #13 Permanent banMakisM1 wrote in post #16665066 I have set the 60D at ISO6400. I can NR ISO12800 but I want to make the decision myself. I have to say though that I haven't used autoISO in a long time. For the 60D I have tested the choices auto-ISO makes in the Av mode and it follows the same logic I do, down to choosing preferentially 1/1.6xFL as a minimum speed and then taking ISO to the ceiling. As EOS5DC has already mentioned, I shoot the 60D at EC+2/3. I arrived to that setting shortly after I bought the camera. Interestingly enough, I am putting my new 5DIII through its paces and looks like I may go to EC 0 or +1/3 I am finding much the same thing with my 6D. My default settings for the 60D are +2/3 EC and +2/3 FEC, and lots of times +1 on both is just fine, too. The 6D overexposes a LOT of stuff at either of those settings. Bodies: 60D, 6D.
Feb 05, 2014 15:36 | #14 I use Auto-ISO frequently in M mode. On the 60D I capped it at 3200. On the 70D I let it go to 6400. Cameras: 7D2, S100
Feb 05, 2014 16:36 | #15 I leave it mostly on Auto ISO capped at 6400. 5Diii | 28/1.8 | 50/1.4 | 100/2.8L | 300/4L
| Latest registered member is zachary24 1422 guests, 127 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
