tmoore99 wrote in post #16671921
I've been reading and reading, even on the Yongnuo web sight and can't figure out which models are capable of what. I'm looking at the YN-56X series.
Yeah, I really wish whoever was making speedlights.net
had continued and kept the site up to date. That was a great resource back when it was current.
a) I want to trigger my 430EX off camera with full E-TTL ability; and/or the ability to adjust the power ratio of the flashes from the on camera master.
Will all the YN56X's do that?
No. Only the 568EXII has master capability.
An old 580EX will do that too won't it? I may wind up with a used 580EX (?)
Yes. The 580EX can be used as a wireless TTL master for the 430EX as a slave.
b) With the ST-E2s selling used for around $50, I may get one of them too. Then I can have 2 OCF. Which Yongnuos will read the ST-E2 signal?
All three: the YN-565EX, the YN-568EX, and the YN-568EXII. However, be aware that an ST-E2 is a more limited master than a 580EX would be: it only understands two groups (A:B) and you can only control the power level via e-TTL ratios. It's pretty similar to using a 550EX as your master unit.
c) I'd really like HSS. I think what I read was clear that the YN-568EX II is the only Yongnuo option there.
This is incorrect. Both the YN-568EX and YN-568EXII can do HSS.
Is it a full functioning master and slave?
The YN-568EXII can be either a wireless eTTL master, a wireless eTTL slave, a Nikon CLS slave, or a dumb optical slave that can fire on the first or second burst it "sees". And you can, of course, always add radio triggers if the optical slave systems don't function well for you (i.e., line of sight/range/reliability will go down if used outside in bright sunlight, and the front panel sensor does need to "see" the master signal).
Back to the 580EX - HSS and everything else, right?
Yes. But it cannot be controlled via a camera menu. OTOH, your 5D classic doesn't have the flash control menu in it, so that may not be an issue until you upgrade camera bodies.
