Thread started 06 Feb 2006 (Monday) 21:58
need help
crissyk81
Feb 06, 2006 21:58 |  #1
Here is an image that my friend took of my niece and I at my wedding this summer. It was my first time outline something and pasting it into a background but it still looks edgy to me...How can I soften the edges without softening the entire photo....
PLEASE HELP !!!!!!!!!!!!!!!
IMAGE: http://img.photobucket.com/albums/v318/crissyk81/amberandi.jpg
Crissy
proud owner of a Canon Powershot G6
ootsk
Joined Jan 2002
Feb 06, 2006 22:22 |  #2
It's your selection process, I think. After you select, click to modify selection and reduce by a few pixels. That will prevent the halo around the girls. Then feather by a few also..it depends on your resolution, so you need to experiment with the amounts of both things I've told you, but it's a start.
DavidW
Feb 08, 2006 14:59 |  #3
Without the Photoshop file (or equivalent) it's almost impossible to rework this - but ootsk is right; feathering the edges when you've made the selection is going to be important, and you may have to modify the selection a little first.
There's also some red-eye that could be usefully dealt with.
David
cforslund
Feb 08, 2006 20:48 as a reply to  @ DavidW's post |  #4
Probably too soft but I gave it a try anyway....As DavidW Said its pretty hard to do anything with this image without the original.... but hey I gave it 30 sec. and got rid of the red eye!
Chris
EOS 5D
EOS 20D
EOS Digital Rebel XT
100-400mm f/4.5-5.6L EF IS Lens
17-40mm f/4l
L USM EF Lens
24-105mm f/4
L IS USM Lens
28-105 f/3.5 - 4.5 II USM EF Lens
50mm f/1.4 Lens
580 Ex Flash
www.forslundphotograph​y.com (external link)
lostdoggy
King Duffus
Joined Aug 2004
Feb 08, 2006 21:19 |  #5
Only if you have the whole PS files w/ layers intact, goto layer/matting/defringe​. Start w/ 1 pixel width and work your way up. Make sure you use undo or ctrl+z to go back each time you increase the pixel width. Definge will help blend the two image together. I also recommend feathering the crop to help blending the image.
I did a little editing recropped and defringe and a little level and color adjustment and some sharpening and noise reduction.
http://i23.photobucket​.com …/amberandips_fi​ltered.jpg (external link)
crissyk81
Feb 12, 2006 23:59 |  #6
lost doggy you did an amazing job....thanks so much for everyones help and advice you are great :D
Crissy
lostdoggy
King Duffus
Joined Aug 2004
Feb 13, 2006 00:16 |  #7
Thank You!!!
952 views & 0 likes for this thread, 5 members have posted to it.
need help
2459 guests, 105 members online
