Ynot wrote in post #16674235
Just picked up a used RRS L-Plate, w/o grip version. Thought I'd give it a try and see if it's really for me.
What plates would I need for a 7D? Mostly shooting 10-22 and 17-40, but I also use a 70-200 f/4 IS on occasion. Can I get by with a single plate or do I need something specifically for the 70-200 also?
Can I go with plates by a different manufacturer that's less $$ or would it spoil the experience so-to-speak? If so, who's reputable?
If it matters I have a Monfrotto 498RC2 head. Anything I need to change there?
Ynot wrote in post #16674265
So I just need 1 more Manfrotto plate, correct?
NManuel01 wrote in post #16674270
Yea, to be able to switch from landscape to portrait.
The RRS 7D (ungripped) L plate won't accept a 1/4" 20 threaded device on the side part, so you won't be able to just attach a second RC2 plate to the L plate and use it. You'll need to get a real Arca-Swiss compatible clamp for your tripod, or at least teh head. When I transitioned from RC2 to Arca-Swiss, I replaced the RC2 clamp on my 488RC2 head with a RRS B2-LR; the current model is the B2-LR2. That's the way I'd go, if I weren't ready to just replace the whole ball head. Kludging something up won't let you appreciate the virtues of an L plate, since the RC2 plate fastened onto the A-S L plate will tend to slip under torque from any significant weight. The L plate will anchor securely; it's the extra RC2 plate that will be the problem.
And, yes, if you move to A-S clamps and plates, you'll need an A-S plate for your 70-200 as well. Mixed systems are the way to insanity.
