Thread started 06 Feb 2006 (Monday) 22:09
How to get a 45 degree angle for focus tests
shniks
Joined Jan 2004
Feb 06, 2006 22:09 |  #1
This is a potentially stupid question, how do I get a perfect 45 degree angle to perform focus testing? All the charts say you should angle the camera at 45 degrees, I dont know an easy and effective way to do this. I have tried using a number of methods, but my charts always look off centre, please help!
mrclark321
Noinker
Feb 06, 2006 22:23 |  #2
Use a level, most have a bubble at 45 degrees.
Or you could use Pythagoras Theorem. :)
Sony A7R3 & A7R4
Sony 16-35 GM
Sony 55mm 1.8
Batis 85mm
Sony 200-600
SWPhotoImaging
Joined Nov 2003
Feb 06, 2006 22:38 |  #3
If you are two feet away, you need to be two feet above the plane of the shot. As long as both distances are equal, it's 45 degrees.
SWPhoto-Imaging
slin100
Joined Sep 2003
Feb 07, 2006 12:47 |  #4
The alternative suggestion is, don't do this. 45 degree focus tests are notoriously inaccurate. You can never be entirely sure where the camera is focused.
A proper test is to shoot perpendicular to a flat target. This leaves no room for doubt as where the plane of focus should be. Place a ruler next to the target to judge the placement of the DOF. Don't put the focus point on the ruler; it should be solely on the flat target.
Steven
7D, 10D, 17-40/4L, 50/1.8 Mk I, 85/1.8, Tamron 28-75/2.8, 28-135/3.5-5.6 IS, 80-200/2.8L, 550EX, Pocket Wizard
1,444 views & 0 likes for this thread, 4 members have posted to it.
1059 guests, 104 members online
