tim1970 wrote in post #16676612
Now that I have a 70-200 f/2.8 IS, I am wondering if I should sell my 135L, in order to get a backup body. I feel like my zoom could easily handle the type of portraits that I was doing with the 135. The only problem, is budget only allows for about $200- $300 plus what I could sell the 135 for. So a 2nd FF sensor is not doable right now. I am starting to do shoot events, and even hope to begin as the primary shooter for a wedding (I have only been the 2nd shooter so far) so a backup body is definitely required. I am just not sure whether to keep what I got, and then just rent a backup body, or go ahead and get something like a 7d or 70d right now.
Heya,
The fact that you're willing to give up the 135L says you don't use it often enough to care. But, you say "could" which implies you haven't tested the 70-200 for the type of portraits you're talking about. That's a big deal, dropping a lens, for a "could" which you may or may not have even tested yet, just based on having another lens with the focal length. The 200 at F2.8 will have more compression than the 135 at F2. But are you going to always do it at 200mm? The 135L is only replaceable, at least to me, at 200mm there. If you shoot below that, then it's not.
But hey, if a 2nd body means more gigs, that means more income, which leads to more lenses and fun stuff anyways. So do what's best for your business in photography.
Very best,
