Ok folks,
I currently own the Impact Varipoles (same as Manfrotto's Autopoles) along with a 9' seamless grey background. My issue is: I have carpet throughout my home. I want to be able to roll out the background onto on the carpet. The trouble with this though, is that if you step on it, you will likely puncture/crinkle/damage the seamless paper backdrop. I'm trying to come up with a removable hard surface that I can put down for shoots, but then easily pack up and put away after a shoot. I don't want to purchase 4' x 8' sheets of plywood because: A) it's too big to fit in our car and B) it's going to be a pain to hide afterwards. The only thing I've managed to come up with, is this interlocking sub-floor. They come in roughly 2' x 2' squares with tongue & groove edges. They are made of a press-board / particle board type material with plastic on the underside. My only concern is that the joints may flex and move around if I walk on it. Thoughts?
![]() | MIME changed to 'text/html' | Content warning: script |
