Can Canon's Digital Lens Optimizer be used for a batch of photos, or is it per photo?
eddieb1 Senior Member 986 posts Likes: 227 Joined Apr 2013 Location: Oregon More info | Feb 10, 2014 17:00 | #1 Can Canon's Digital Lens Optimizer be used for a batch of photos, or is it per photo?
digitalparadise Awaiting the title ferry... More info | Feb 10, 2014 19:54 | #2 |
digitalparadise Awaiting the title ferry... More info | Feb 10, 2014 20:03 | #3 Yes it will. Just tried it. Highlight all the images you want to apply it to and hit tune. It is very slow. Image Editing OK
groundloop Senior Member 995 posts Likes: 45 Joined Jun 2012 More info | Feb 10, 2014 20:08 | #4 eddieb1 wrote in post #16679408 Can Canon's Digital Lens Optimizer be used for a batch of photos, or is it per photo? After you setup the lens corrections in one photo you can copy the recipe to the clipboard, then chose all the photos you want to apply that correction to and paste recipe from clipboard.
digitalparadise Awaiting the title ferry... More info | Feb 10, 2014 20:20 | #5 groundloop wrote in post #16679797 After you setup the lens corrections in one photo you can copy the recipe to the clipboard, then chose all the photos you want to apply that correction to and paste recipe from clipboard. I think that's what you were getting at anyway. I was not sure about the recipe part. Not sure how to verify it works. Using the method I tried showed me the progress of the highlighted files. I know it works when you make several adjustments to the RAW tab and other adjustments. Makes sense and it would be faster. You only need one pass using recipe. Image Editing OK
iriches Member 81 posts Joined Apr 2005 Location: UK More info | Feb 11, 2014 05:50 | #6 digital paradise wrote in post #16679786 ...but it appears Canon has not yet submitted the data for the for 24-70 MK2 yet... Update to the latest DPP (I have 3.13.51.1). The latest lens updates only seem to appear in the latest DPP versions. The version I listed has the "EF 24-70mm F2.8 II USM" showing up as a profile available for download for me. Ian Riches - Bedford, UK.
groundloop Senior Member 995 posts Likes: 45 Joined Jun 2012 More info | Feb 11, 2014 07:22 | #7 digital paradise wrote in post #16679832 Not sure how to verify it works. Once a lens correction is applied there's a small lens icon which appears on the thumbnail. Sometimes the lens corrections doesn't show up right away in the photo displayed in DPP, but it will be applied to the output file. I know it works when you make several adjustments to the RAW tab and other adjustments. Makes sense and it would be faster. You only need one pass using recipe. Yep, you can move through photos quite fast in DPP using recipes. And as someone else pointed out, it's worth it to go to the Canon website and make sure you have the latest greatest version of DPP.
| Latest registered member is griggt 662 guests, 121 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
