Thread started 11 Feb 2014 (Tuesday) 14:48
Should I get the 35mm f2 IS or 85mm 1.8?
The ­ Dark ­ Knight
Joined Apr 2012
Feb 11, 2014 14:48 |  #1
Been looking to add a nice prime for a while, in the $500 or under range. I noticed the 35mm has dropped in price quite a bit since introduction, so I'm giving it a look.
I shoot a lot in the 35-50 and 70-90 ranges, so either prime would be great. I'll get more use out of the 35mm - I can see it as being a walkaround lens on either my 6D or SL1 (depending on how much DSLR I want to carry that day). I already do have the 40mm prime which is great for walkaround on the 6D, but I feel like it gets a tad too tight on a crop sensor.
But the 85mm I think fills a larger "gap" in my current equipment - I don't have anything faster than f/4 in that range.
S ­ Sanderson
Joined Mar 2013
Feb 11, 2014 15:59 |  #2
They're very different lenses, with very different uses. In general terms the 35mm f2 would probably be the most useful. I have the 35mm f2 IS and find to be an excellent lens, sharp at f2.
5D Mk III, Canon 35 f/2 IS USM, Canon 24-105 f/4L, Canon 100 f/2.8L, Sigma 50 f/1.4 Art, Canon Speedlite 430EX II
silma
Gallery: 6 photos
Joined Jul 2012
Feb 11, 2014 16:04 |  #3
I own a 35mm non IS and a 85 f1.8, both are used on crop (60D). I find the 35 really cool as lightweight everyday lens (I'm not a pro); the pancake could be very similar, it's a little bit longer, but you can zoom out with your feet, but it's also lightweight, sharp, silent and quite fast. That said I'd go for the 85 as it can give a whole new pont of view and a magical bokeh...its AF is also very fast so you could use it as short telepohoto for fast moving subjects
my flickr (external link)
my dreamstime (external link)
Bearmann
Location: I live behind Graceland in a tool shed. I often meet the man early in the morning at Krispy Kreme.
Feb 11, 2014 16:15 |  #4
I have them both and love each of them. Since you already have the 40 2.8 and the 50 1.8, I think I would get the 85 as you don't have a fast lens in that focal length range.
Barry
http://b-r-s-photo.zenfolio.com (external link) (remove the dashes)
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Feb 11, 2014 21:03 |  #5
The Dark Knight wrote in post #16681674 (external link)
Heya,
I use the 35mm F2 IS & 85mm F1.8 the most. I like those two focal lengths a lot. The 35mm is my walk around lens mostly and go-to for nearly everything. The 85 is more specialized and limited than the 35 is. The 35 is also amazing in low light, 4 stop IS performance, great aperture, and sharp at F2.
I say get both. Maybe just figure out which to get first.
Very best,
kin2son
Joined May 2011
Feb 11, 2014 21:11 |  #6
I'd get the 85 first.
You already have the pancake, the 35IS is only a stop faster, and whether IS is actually useful for you is up for debate. Both are sharp wide open.
Like you said the fastest lens you have in 70mm+ is f4, and f1.8 is more than a full stop. So go 85 first.
5D3 Gripped / 17-40L / Σ35 / 40 Pancake / Zeiss 50 MP / Σ85 / 100L Macro / 70-200 f2.8L II IS / 430 EX II / 580 EX II / Canon 2xIII TC / Kenko Ext. Tubes
EOS M / EF-M 18-55 / EF-M 22f2 / Ricoh GR aka Ultimate street camera :p
Flickr (external link) | My Images on Getty®‎ (external link)
Nick_Reading.UK
Joined Nov 2011
Feb 12, 2014 01:48 |  #7
Both are amazing.... But if you get the 35mm then I don't see the need for your 40mm pancake, useless size and weight are why you have it in the first place?
EOS 5Dmk3 X2, 60D, EF24-70mm f2.8L mk2, EF70-200mm f2.8L IS mk2, EF85mm f1.8, EF50mm f1.4, EF50mm f1.8 mk1(350D with 18-55mm Sh"kit" lens).
Speedlite 600EX-RT, 430EX II Flash. manfrotto 190XDB tripod, Giottos GTMML 3290B Monopod, B+W 77mm 110 Single Coated filter, Hama 77mm Variable Neutral Density Filter.
FarmerTed1971
fondling the 5D4
Gallery: 66 photos
Joined Sep 2013
Feb 12, 2014 01:52 |  #8
kin2son wrote in post #16682486 (external link)
You already have the pancake...
This.
Getting better at this - Fuji X-t5 & X-t3 - 16 1.4 - 35/50/90 f2 - 50-140 - flickr (external link) - www.scottaticephoto.co​m (external link)
1,658 views & 0 likes for this thread, 8 members have posted to it.
1461 guests, 131 members online
