Thread started 12 Feb 2014 (Wednesday) 11:39
can you help me to print and create a customize profile?
mantra
Feb 12, 2014 11:39 |  #1
Hi
may i ask 2 questions?
i have an eizo monitor ,epson 3880 , i have xrite color munki and spider , i use mostly colormunki
well sometime i print in a lab with a printer stylus pro 9800 ,and they use mac i'm a windows user
1)
may i know where can i download the paper profile
Epson Premium Semimatte for the stylus pro 9800 for windows?
i found an espon page but the links don't work
well with time i did learn to make good prints with my 3880 but now i would like to use the stylus pro 9800
2)
well seeing the stylus pro 9800 prints have different lights ,i scanned with an hi-end scanner and i would like to create my personal icc profile for photoshop to match as possible .
thanks a lot
have a great capture
canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
3 analogic Hasselblad and 2 anologic Mamiya
Mark ­ Vuleta
Gallery: 48 photos
Feb 13, 2014 00:38 |  #2
Hi Mantra
1: Download the printer driver for the stylus pro 9800 and install it. It will load the Epsom Paper ICC files to the appropriate place (windows/system 32/spool/drivers/colou​r). You can then remove the printer but the ICC files will remain. You can then soft-proof using the appropriate ICC file.
That will be as close as you can get without obtaining your printers ICC files (which may be the OEM ones from Epsom or one that they may have created themselves)
2: Sorry, I'm not sure what you are asking.
Cheers
Mark
mantra
Feb 13, 2014 01:24 |  #3
Mark Vuleta wrote in post #16685726 (external link)
Hi Mantra
Cheers
Mark
Hi Mark
thanks for the answer
1)
but this could mess up my system , could not?
i mean i have my printer drivers installed
2)
the lab prints are different , they don't look like what i see in my eizo (calibrated) and with proof enabled , and they don't like my photos printed with my epson 3880
they told me to make some adjustaments in photoshop to make the lab print match with my epson 3880 and after save the profile
thanks
tzalman
Fatal attraction.
Feb 13, 2014 02:30 |  #4
mantra wrote in post #16685776 (external link)
Hi Mark
1)
2)
thanks
You can get the profile on the Epson site without the driver.
You can have multiple printer drivers without messing up your system. What do people with two printers do?
You can use a curve layer adjustment in PS to get a match with a test print and then save the curve as a .crv file.
Elie / אלי
Mark ­ Vuleta
Gallery: 48 photos
Feb 13, 2014 02:30 |  #5
1)
thanks
Installing the 9800 driver wont have any effect on your driver for the 3880. It will simply add the 9800 to the printer list and provide the ICC files for it. Un-installing the driver will get the printer off the list but will still leave the ICC files.
These are what you soft-proof to when you are sending out to the print service unless they provide you with their own ICC file to use.
2)
What they are telling you doesn't make sence. Possibly, they may be suggesting that you set up an "action" or "pre-set" that you could apply to your files to make them look like the prints from the 3880 but that is not the correct path to take.
If your monitor is calibrated & profiled correctly and the prints you are getting out of the 3880 utilizing the correct profiles, ink and paper set-up, are a good match for your monitor, it appears that you seem to have your colour management workflow correct.
If the prints you get back from the 9800 are quite different to what you are expecting, you need to check to see if you have soft-proofed correctly (which, if you didn't have the ICC profile, you could not have) or the other print service is doing some automatic corrections &/or colour space conversions inappropriately.
Your print service should be able to provide you the ICC file, they should also advise you what colour space they prefer, while file type they prefer and advise if they do any auto-corrections. You should request that auto corrections be not applied so that they do not alter the image file you have provided and soft-proofed for.
mantra
Feb 13, 2014 02:37 |  #6
Mark Vuleta wrote in post #16685820 (external link)
thanks a lot Mark ,they use mac osx , do you think i can import their profile in windows
the problem is that the luminocity doesn't match , so when they told me to edit my photo to match their print and after create a profile ,is unless?
thanks again Mark
Mark ­ Vuleta
Gallery: 48 photos
Feb 13, 2014 02:58 |  #7
The ICC file is a standard format, the operating system should be irrelevant.
The whole point of calibration and profiling is to obtain a standard as close as possible across a whole range of imaging devices i.e cameras, monitors, printers, scanners etc.
While it is acceptable to perform minor tweaks to files going to outside suppliers, they should be pretty close.
The answer to a couple of questions should help.
1: When you calibrated/profiled your monitor, what luminocity did you end up with, gamma setting did you use and what did you end up with.
2: How did you soft-proof the file that came back either too dark or too light without the correct ICC file?
3: What viewing conditions are you viewing the print in. Prints need to be viewed in brighter conditions that what you would normally have your monitor in. Good daylight but without direct sun is preferred.
mantra
Feb 13, 2014 10:16 |  #8
tzalman wrote in post #16685819 (external link)
thanks
but for example in the epson site there is not the profile alone
i found a page but the links don't work
for example can you find the Epson Premium Semimatte profile for stylus pro 9800 ?
i don't have 2 printers , a lab uses this printer
stylus pro 9800
tonylong
...winded
Gallery: 60 photos
Feb 13, 2014 13:59 |  #9
For the Epson printer/paper combination you may want to just install the driver (the Epson site should have it) -- did you try that to see if you can softproof using the Epson built-in paper profiles?
Tony
mantra
Feb 14, 2014 01:11 |  #10
tonylong wrote in post #16687024 (external link)
hi
in a forum i found
Advice from epson if PLPP(260) not available use Premium Glossy Photo Paper (250) or Premium Glossy Photopaper. Do not select Premium Luster Photo Paper (250) or Premium Luster Photopaper. This advice is in the instruction sheet accompanying the 16" roll of PLPP(260) I am using. correct profiles are on my 4880 disk and would be available from epson.
Mark ­ Vuleta
Gallery: 48 photos
Feb 14, 2014 01:27 |  #11
mantra wrote in post #16686442 (external link)
for example can you find the Epson Premium Semimatte profile for [FONT=Arial][FONT=Aria​l]stylus pro 9800 ?
I got it from the printer driver that I downloaded. It is called:
Pro9800 7800PSmPP250 (this is for what I assume is a 250gm weighted paper)
There are a couple of variants which I assume are for lighter papers, you would need to check with your printer which weight paper they are using.
Have a look here:
https://files.support.​epson.com …o78_/pro78_rf/t​rble_2.htm (external link)
This is a table of papers with various ICC files associated with them.
If you still cannot get hold of the ICC file, PM me with your email address & I will send it to you. It is 780kB, so, not that big of a file.
mantra
Feb 14, 2014 08:30 |  #12
Mark Vuleta wrote in post #16688323 (external link)
Have a look here:
thanks Mark
i will install the drivers if i need some included profiles
in short you install the driver , you take what do you need , and uninstall the drivers?
i printed some photos in the lap using your profiles and the look great!
thanks again!
2,300 views & 0 likes for this thread, 4 members have posted to it.
1053 guests, 103 members online
