Thread started 14 Feb 2014 (Friday) 00:26
Musing about fixed max aperture zooms . . .
dodgyexposure
Gallery: 14 photos
Joined Jul 2012
Feb 14, 2014 00:26 |  #1
Bear with me, as I talk this out. Innocent daydreaming about focal length and aperture ratios has led me to a question that must have a simple answer . . .
Take a 24-105 f4 for example, for ease of mathematics. For f4 at 105mm, the physical aperture must be about 26mm in diameter.
But for f4 at 24mm, the physical aperture is about 6mm (to satisfy the ratio).
Given that it is the same aperture apparatus, why is it that you can't open the aperture to 26mm when the focal length is 24mm, and therefore have a ratio of 1 (give or take)?
I'm assuming that there is a simple explanation. Before I outline any hare-brained ideas that occurred to me, can someone with real knowledge explain this?
Cheers, Damien
jack880
Gallery: 13 photos
Joined Apr 2011
Feb 14, 2014 00:30 |  #2
Think about it.
I'm surprised you cant figure it out for yourself.
Neither can I though...!
https://www.flickr.com​/photos/jackhenriques/ (external link)
1DX, 7D, 20D, G7X II, 70-200 f/2.8 L IS II, 24-70 f/2.8 L, 16-35 f/2.8 L II, 50 f/1.8 II, 50 f/1.4, TS-E 17 f/4 L, 8-15 f/4 L, Sigma 17-50 f/2.8, Sigma 8-16 f/4.5-5.6, Sigma 150 f/2.8 macro, x1.4 extender II, Kenko extension tubes, 430 EX II x 2, DJI Mavic Air
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Feb 14, 2014 00:36 |  #3
dodgyexposure wrote in post #16688271 (external link)
Heya,
I imagine it's because the lens is physically in a different spot, it moves forward and backwards inside, right? So it's not as simple as just considering it's ratio the same and going with aperture/length. At 26mm aperture opening, with the lens at 24mm, I think the internal lens moves forward, further away from the rear element. And at 105mm, it's closest to the back, near the element.
Hell I don't know. This is why I don't make these for a living.
Very best,
kawi_200
Gallery: 10 photos
Joined Jul 2011
Feb 14, 2014 00:43 |  #4
MalVeauX wrote in post #16688277 (external link)
Heya,
Very best,
^ This is along with my thinking.
Have you ever looked down the front element and fiddled with a lens? Zoom in and out, play with the DOF preview button to close the iris and see what it looks like and what it does? If you do, you will notice that it physically looks smaller when zoomed out and larger when zoomed in.
My only guess why this is would be because lenses are basically a group of magnifying glasses working together to create a clear image. And when positioned to magnify as weakly as possible or maybe demagnify (zoomed out) they make things appear smaller, such as the aperture iris.
5D4 | 8-15L | 28-135mm f/3.5-5.6 IS | 24L II | 40mm pancake | 100L IS | 70-200mm f/2.8L IS mk2 | 400mm f/4 DO IS
1Tanker
Feb 14, 2014 01:25 as a reply to  @ kawi_200's post |  #5
I've wondered the same thing... was thinking about it just a few days ago.
Good question, i look forward to the answer(s). :)
Kel
Gear
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Feb 14, 2014 02:15 |  #6
The f/number isn't actually determined by the physical size of the aperture blade opening, but by the optical image of the aperture as seen through the front of the lens. As the zoom range changes the perceived size will also change.
http://en.wikipedia.or​g/wiki/F-number (external link)
In optics, the f-number (sometimes called focal ratio, f-ratio, f-stop, or relative aperture[1]) of an optical system is the ratio of the lens's focal length to the diameter of the entrance pupil.[2] It is a dimensionless number that is a quantitative measure of lens speed, and an important concept in photography.
http://en.wikipedia.or​g/wiki/Entrance_pupil (external link)
In an optical system, the entrance pupil is the optical image of the physical aperture stop, as 'seen' through the front of the lens system. The corresponding image of the aperture as seen through the back of the lens system is called the exit pupil. If there is no lens in front of the aperture (as in a pinhole camera), the entrance pupil's location and size are identical to those of the aperture. Optical elements in front of the aperture will produce a magnified or diminished image that is displaced from the location of the physical aperture. The entrance pupil is usually a virtual image: it lies behind the first optical surface of the system.
Hopefully this will help confuse things even more.
500px (external link)
1x (external link)
instagram (external link)
dodgyexposure
Gallery: 14 photos
Joined Jul 2012
Feb 16, 2014 18:45 |  #7
Thanks! I thought that the answer would be optical, but didn't expect it to be definitional!
Cheers, Damien
1,014 views & 0 likes for this thread, 6 members have posted to it.
1314 guests, 128 members online
