Thread started 16 Feb 2014 (Sunday) 13:43
My first studio backdrop. Need help!
Aressem
Gallery: 39 photos
Feb 16, 2014 13:43 |  #1
So I purchased the Impact Varipoles and a Savage Thunder Grey seamless backdrop and finally got around to setting it up last night. I'm super impressed with everything so far, BUT, I have one question! In the photo below, you can see that I have pinched 4 clamps onto the end of the roll to weigh it down/keep it straight. when rolling the background down, alone, it gets difficult once it touches the ground to pull it out across the floor with out crinkling the paper. I'm hoping that there something that exists to assist with this. What I have in mind is 2 pieces of thin material, perhaps 9ft long x 1" x 1/4". The idea would be to sandwich the end of the roll between the material and fasten them together, 'pinching' the backdrop and adding weight and a rigid edge to grab and pull down on.
Does something like this exist? Did I lose anyone with my terrible description? :P
Links please and thanks in advance!
HTTP response: 403 | MIME changed to 'text/plain'
Ryan Mackay WEBSITE (external link) | FACEBOOK (external link) | GEAR LIST | Buy & Sell Feedback: 1, 2, 3, 4, 5
Aressem
Gallery: 39 photos
Feb 16, 2014 15:15 |  #2
anyone??
Talley
Talley Whacker
Gallery: 46 photos
Joined Dec 2011
Feb 16, 2014 15:25 |  #3
I like your shelves to the right.
other than that I can't help ya, sorry.
A7rIII | A7III | 12-24 F4 | 16-35 GM | 28-75 2.8 | 100-400 GM | 12mm 2.8 Fisheye | 35mm 2.8 | 85mm 1.8 | 35A | 85A | 200mm L F2 IS | MC-11
My Gear Archive
BrickR
Joined Mar 2011
Feb 16, 2014 15:34 |  #4
You have the right idea. Wood strips from Home Depot or some place like that. Use the clamps you already have to hold the 2 strips in place with the paper sandwiched in between. :)
When you pull the paper out, pull it straight out, then let it lower to floor. Walk back first, then walk forward to let the paper gracefully settle on the floor ;)
My junk
The grass isn't greener on the other side, it's green where you water it.
flowrider
Gallery: 127 photos
Feb 17, 2014 01:27 |  #5
Looking at your photo I would reverse the roll on the rod. Have the paper come off the back (closest to the wall) so you don't have go against the natural curve of the paper. At least that's what I can glean from the photo.
~Steve~
~ My Website-stevelowephoto.com (external link) ~ Facebook (external link)
Feedback Feedback Feedback
Whortleberry
Joined Dec 2011
Feb 17, 2014 04:50 |  #6
Ryan: To directly answer your question, yes. Manfrotto make a 2 section background paper counterweight http://www.manfrotto.c​o.uk …round-paper-counterweight (external link) which basically you wrap the end of your paper round and clip under the 'C' section cover.
Two other points of which you may not be aware.
  1. As 'flowrider' mentions, the paper is back-to-front. Despite appearances (sometimes) there is definitly a front and a back to rolls of paper. The side intended to be used is on the inside of the curl. Hence, you've got it set up a*se about face.:oops:
  2. There is a tensioning device built into the 'Expan' roll holders so that you can adjust the tension and stop the paper unrollng by itself. As below (at least, that's how the original Expan is designed, clones etc may vary).
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/02/3/LQ_677326.jpg
Image hosted by forum (677326) © Whortleberry [SHARE LINK]
Phil ǁ Kershaw Soho Reflex: 4¼" Ross Xpres, 6½" Aldis, Super XX/ABC Pyro in 24 DDS, HP3/Meritol Metol in RFH, Johnson 'Scales' brand flash powder. Kodak Duo Six-20/Verichrome Pan. Other odd bits over the decades, simply to get the job done - not merely to polish and brag about cos I'm too mean to buy the polish!
FlickR (external link) ◄► "The Other Yongnuo User Guide v4.12" by Clive Bolton (external link) ◄► UK Railway Photographs 1906-79 (external link)
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Feb 17, 2014 07:14 |  #7
flowrider wrote in post #16695384 (external link)
good catch, and agreed.
i usually roll out enough to cover the floor at one time, allowing it to roll back up on itself when it hits the floor, lock the roll down and then roll out the length remaining on the floor.
Edit to add, I have a stick that I use to help unroll the stuff on the floor but I just drop it in and start unrolling. Doesn't have to be the full width of the paper. After it unrolls I leave it at the end of the roll while I secure the rest of the paper.
Aressem
Gallery: 39 photos
Feb 17, 2014 10:26 |  #8
Ahahaha. Oh man, thanks you guys. Can't believe I had it backwards. Despite the whoops, I ha a chance to take a test shot of my brother last night and am happy with the results despite my backwards roll, hehe. Lemme know what you think! Just one light in a large softbox. Will add more lights as I learn.
IMAGE: https://scontent-b-pao.xx.fbcdn.net/hphotos-prn2/t31/1960992_584604054957873_517136534_o.jpg
Gallery: 15 photos
Joined Jun 2011
Feb 17, 2014 10:35 as a reply to  @ Aressem's post |  #9
Looks good. Are you using a speedlight in the box?
i'd put the light up a bit higher. Also the positioning of the shadow on the background kinda bugs me, either pull the subject off the background a bit or push him back towards it. Another way to accomplish the same thing is to skew the angle you are shooting towards the backdrop. For example, rotate camera, subject and light to the right, and the shadow will move left, and vice versa.
Aressem
Gallery: 39 photos
Feb 17, 2014 11:55 |  #10
hes gone wrote in post #16696129 (external link)
=he's gone;16696129]Looks good. Are you using a speedlight in the box?
No speed light. It's a an elinchrom ranger on the lowest possible power setting. I wish it went lower actually. :( it's being fired through a photoflex 3' x 4' softbox. I still have to move stuff around and need to setup a proper subfloor so that I have more room to pull my subject away from the background. I'd eventually like to get a couple strip boxes and setup a separation and background light. Baby steps... ;) a light meter is on the wish list too!
Rushmore
Joined Nov 2012
Feb 17, 2014 12:00 |  #11
nice selection of moustaches on the fridge!
Reppin the 5D iii and 7D with some lenses and some lights
LIKE MY PHOTOGRAPHY PAGE (external link)
MY STUDIO FACEBOOK PAGE (external link)
www.phlashworx.co.uk (external link)
My Photography Website (external link)
windpig
Chopped liver
Feb 17, 2014 16:10 |  #12
Aressem wrote in post #16696289 (external link)
They go pretty low when on channel B. Only reason I need it lower is when using with ambient, then I'll through some ND gel on.
the manfotto paper end weight that was link work really well, but are a little tricky to put on, along with the cost being a little high.
Go ahead, spin the wheel.
Aressem
Gallery: 39 photos
Feb 17, 2014 16:37 |  #13
windpig wrote in post #16696893 (external link)
Ya. Still not low enough, even on channel B at 1.5 (lowest power setting). I'm trying to shoot wide open with my Siggy 35. Settings were ISO 100, 1/250 (not that this matters) and f/1.8. Subject was hot. Had to stop down to f/2 to f/2.8. :(
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Feb 17, 2014 16:54 |  #14
Aressem wrote in post #16696977 (external link)
Why shoot wide open against grey seemless? Shoot at f/8. The background is grey, you're not going to get better bokeh wide open. ;)
As far as subject separation, you can do that with one light. If you feather the light across the subject so that the subject is in the front of the beam spread, the rear of the beam with hit the background on the opposite side of the subject. Just check my avatar, that was one light. Adding a reflector for fill will open up the shadows a bit as well.
500px (external link)
1x (external link)
instagram (external link)
flowrider
Gallery: 127 photos
Feb 17, 2014 16:55 |  #15
If you pull them farther from the background you can use a smaller f-stop. I usually shoot at f/6.3 and higher as there's less need to blur out the background.
~Steve~
2,947 views & 0 likes for this thread, 9 members have posted to it.
673 guests, 122 members online
