Thread started 16 Feb 2014 (Sunday) 13:48
problems with XTi 400d
babbobubba
Joined Jul 2013
Feb 16, 2014 13:48 |  #1
When I turn on my XTI 400d I see only the info screen, not what camera is aimed at. Battery display says battery is charged (but I put it on the charger for a while anyway). Autofocus not working. I reverted to default settings. No change. Memory card is empty, formatted and in place. What is going on? It has been a couple of months since I used the camera.
DC ­ Fan
Feb 16, 2014 15:09 |  #2
babbobubba wrote in post #16693987 (external link)
Among other things, the XTi is not a Live View camera. When the camera is powered up,you'll only see the info screen.
John ­ from ­ PA
Joined May 2003
Feb 16, 2014 15:23 |  #3
Do you get an image for a short period of time after taking an image? As far as autofocus, make certain the switch marked A M is in the A position.
apersson850
Obviously it's a good thing
Gallery: 35 photos
Feb 17, 2014 05:49 as a reply to  @ John from PA's post |  #4
Actually, it's AF/MF, and that switch is on the lens, not on the camera. Only very old lenses had this switch marked AF/M.
Anders
babbobubba
Joined Jul 2013
Feb 17, 2014 10:32 as a reply to  @ apersson850's post |  #5
Sorry. I forgot to add that the shutter will not work. I press button but nothing happens.
apersson850
Gallery: 35 photos
Feb 17, 2014 13:11 as a reply to  @ babbobubba's post |  #6
Does the shutter work in MF, then?
Anders
babbobubba
Joined Jul 2013
Feb 19, 2014 19:45 as a reply to  @ apersson850's post |  #7
Shutter works in neither mode. Lens does not autofocus when shutter is partially depressed. Doesn't seem to matter that I too am partially depressed by this.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Feb 19, 2014 23:04 |  #8
babbobubba wrote in post #16702780 (external link)
Did you activate back button focusing so that the * button does focusing? I suggest you reset all camera settings and cf values, and try again.
babbobubba
Joined Jul 2013
Feb 20, 2014 17:45 |  #9
I reset everything to default.
klassenl
Feb 20, 2014 21:54 as a reply to  @ babbobubba's post |  #10
Did you take the lens cap off?
Canon 60d - EF 17-40 f4 L - Canon 15-85 IS USM - EF-s 55-250 STM - Nissin Di622ii - Manfrotto 7302YB
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Feb 20, 2014 22:06 |  #11
babbobubba wrote in post #16704984 (external link)
Custom functions have their own reset I believe.
gofer
Feb 21, 2014 03:21 as a reply to  @ TeamSpeed's post |  #12
Assuming you mean that you cannot see what the camera is aimed at when looking through the viewfinder, it is possible that the mirror is not in its normal or lower position. The early Rebel's where prone to a small pin breaking in the mirror box that has something to do with the mirror 'flip' mechanism. If that has broken the mirror could be jammed in the 'locked up' position. I'm not sure if the XTi suffered from this problem but try taking the lens off and having a look to see if the mirror is actually in the lowered or raised position.
Steve.
babbobubba
Joined Jul 2013
Feb 22, 2014 19:57 |  #13
DC fan reminded me that this is not a live-view camera. When I checked the mirror as gofer suggested I discovered that the shutter (and mirror) work when the lens is dismounted. It's the only lens I have so I can't test with another. Any ideas from these facts? And yes, klassenl, the lens cap is off.
1,705 views & 0 likes for this thread, 7 members have posted to it.
2216 guests, 124 members online
