Thread started 16 Feb 2014 (Sunday) 15:18
Disaster (nearly) today with BlackRapid
Ryan0751
Joined Oct 2012
Feb 16, 2014 15:18 |  #1
I went out this afternoon with my Canon 5D III and 70-200 F2.8 II to take some Boston shots after the snow storm yesterday.
Since this setup is pretty heavy (5D is gripped, with L bracket), I attached my BR strap to the lens.
I was walking around, and everything was fine, when all of a sudden, somehow, the lens release must have been pushed rubbing up against my side, or my hand, who knows...
The 5D body fell off the 70-200, right onto the wet brick sidewalk. It made the worst sound possible, and some lady had a more horrified look on her face then I did. My screen protector flew off the camera.
Fortunately it landed on it's back. Nothing entered the camera mirror box area that I can see.
Miraculously, the camera still works. But, there is a big crack in the chassis up near the focus point button, and the LCD cover for the info window was damaged as well. I drove directly to the local camera shop, and off to Canon it is going. It looks like damage should be limited to about $250.
Now I can't really truly blame the black rapid, since the strap and mechanism didn't fail. I've been using a black rapid for a couple of years now without a problem... but this is surely something to be careful about!
I thought surely I had just destroyed a $3500 camera...
Canon 5D III, Fuji X100s, Sigma 15mm (Fisheye), 16-35 F2.8 L II, 24-70 F2.8 L II, 70-200 F2.8 IS II L, 100 2.8 Macro L, 1.4X TC, 3 x 600 EX-RT, ST-E3, Nodal Ninja Ultimate M2 with EZ Leveler
http://www.flickr.com/​photos/ryanruel (external link)
Lastblackdog
Gallery: 472 photos
Joined Feb 2013
Feb 16, 2014 15:39 |  #2
Hi, same thing happened to me over the Christmas time. The repair cost me £300 ($450) so you were luckier (?) than me.
When I posted my experience other posters suggested that I get the lanyard that connects the camera body to the strap. This I did.
However, the fact that Black Rapid have this accessory available suggests that they are aware of the problem.
I think that in the hanging down position the release button bounced of my iPhone which I carry in my front trouser pocket.
The experience has dampened my confidence in the Black Rapid strap.
The 5D M3 / 70-200 II F2.8 combination is a tad loose in my opinion. Would the same thing have happened with a lens that is a tighter fit?
It is hard to concentrate on looking for good potential images when you are worrying about your kit.
https://www.flickr.com​/photos/lastblackdog/ (external link)
Ryan0751
Joined Oct 2012
Feb 16, 2014 15:45 |  #3
I know the feeling. My confidence in the strap is shot. Gone. And I love the black rapid.
$250 is what I was quoted, but it might be more...
Now I am thinking of going to a regular strap that uses the camera strap lugs.
BrickR
Joined Mar 2011
Feb 16, 2014 16:24 |  #4
Nearly?? LOL! Sounds like it was a disaster. I guess it isn't a real disaster until it is over $500 in damages :(
In all seriousness now: That sucks. I used a BR style strap but didn't feel comfortable completely. Preferred the Optech sling strap that connects to the OEM strap connectors. Nothing can back off or unscrew from.
My junk
The grass isn't greener on the other side, it's green where you water it.
xeodragon
Joined Aug 2011
Feb 16, 2014 17:01 |  #5
Ryan0751 wrote in post #16694264 (external link)
May I kindly suggest the Luma Cinch v2 :)?
Chef678
Joined Jul 2013
Feb 16, 2014 17:03 as a reply to  @ BrickR's post |  #6
Vulture Equipment Works VEW-A4S .that would not have happen.
jtmiv
Gallery: 17 photos
Joined Jan 2013
Feb 16, 2014 17:37 |  #7
Dear Ryan,
I'm sorry for your troubles. Spend $ 25.00 and get an OP/TECH sling instead of throwing more money at the problem. It ain't the coolest thing on the market but it WORKS! I'm sure you know by now that more money expended does not equal greater security.
Regards,
Tim Murphy :D
"Then the coal company came with the world's largest shovel
And they tortured the timber and stripped all the land
Well, they dug for their coal till the land was forsaken
Then they wrote it all down as the progress of man"
Ryan0751
Joined Oct 2012
Feb 16, 2014 17:49 |  #8
xeodragon wrote in post #16694429 (external link)
That looks interesting. If you have the lug piece on the 70-200, how do you switch to a standard lens? It doesn't look like it can be unclipped easily?
Ryan0751
Joined Oct 2012
Feb 16, 2014 17:55 |  #9
jtmiv wrote in post #16694504 (external link)
Dear Ryan,
Regards,
Tim Murphy :D
I don't know... that doesn't look sturdy. First, the cloth straps to the camera body. Second... those plastic clips (one of those just broke off on my bag today, bad day for camera gear for me).
The 5D III with 70-200 F2.8, battery grip is probably about 6 pounds!
jtmiv
Gallery: 17 photos
Joined Jan 2013
Feb 16, 2014 18:07 |  #10
Dear Ryan,
I routinely walk around with a 1DMK2 and a Sigma 150-500 attached to an OP/TECH sling, that's about 8 pounds. It gives no indication that it will ever fail and the web straps that attach to the camera lugs are not the least bit worn. I bought the rig used from a pro sports shooter that usually used it with a 70/200f2.8 or 300f2.8.
It's good stuff, it's cheap, and it's made in Montana. What more do you need to know? Try it, you'll like it.
Regards,
Tim Murphy :D
Scrumhalf
Gallery: 158 photos
Joined Jul 2012
Feb 16, 2014 18:10 |  #11
Not sure what this failure has to do with the sling. Sounds like the lens came loose from the mount. If the strap was attached to the camera, then the lens would have fallen. I don't anything short of a redundant solution where the lens attached to the body independently would have saved both the body and the lens.
Sam
5D4 | R7 | 7D2 | Reasonably good glass
If I don't get the shots I want with the gear I have, the only optics I need to examine is the mirror on the bathroom wall. The root cause will be there.
mike325
Joined Apr 2011
Feb 16, 2014 18:15 |  #12
Scrumhalf wrote in post #16694582 (external link)
Not sure what this failure has to do with the sling. Sounds like the lens came loose from the mount. If the strap was attached to the camera, then the lens would have fallen. I don't anything short of a redundant solution where the strap is attached to the body independently would have saved both the body and the lens.
I was thinking the same. How did the lens come off the camera? And the lens did not drop?
Sorry for your misfortune. Hopefully you get it back good as new.
panicatnabisco: Sometimes money can buy happiness. Example; camera gear.
Ryan0751
Joined Oct 2012
Feb 16, 2014 18:15 |  #13
I think the point is that the strap placed the camera in a position where it was more likely to be accidentally released, and yes, that a strap that connected both components would have helped.
Ryan0751
Joined Oct 2012
Feb 16, 2014 18:17 |  #14
mike325 wrote in post #16694592 (external link)
I have no idea really. I was just walking along, and my jacket or something must have hit the release, and then the camera just twisted the right way. The lens was still attached to the black rapid.
I've used this same setup for a couple of years now, so this could be a freak occurrence, but come on... there must be a better solution.
Ryan0751
Joined Oct 2012
Feb 16, 2014 18:18 |  #15
jtmiv wrote in post #16694577 (external link)
Dear Ryan,
Regards,
Tim Murphy :D
Ok, I don't doubt your knowledge, just judging by the pictures I see on the web.
So you don't use the strap with the lens at all, just the body?
41,156 views & 0 likes for this thread, 44 members have posted to it.
1422 guests, 127 members online
