Can you use the latest 600RT flash in E-TTL radio mode and also multi-flash radio mode with bodies other than the 5D3 or 1DX? Looking at the instruction manual on-line is unclear. Specifically I'm using 1D4, 1DS3, and 1D3 bodies. Thanks.
cristphoto Goldmember 1,052 posts Likes: 72 Joined Feb 2010 Location: Maryland More info | Feb 17, 2014 09:35 | #1 Can you use the latest 600RT flash in E-TTL radio mode and also multi-flash radio mode with bodies other than the 5D3 or 1DX? Looking at the instruction manual on-line is unclear. Specifically I'm using 1D4, 1DS3, and 1D3 bodies. Thanks. 1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
apersson850 Obviously it's a good thing More info | Feb 17, 2014 13:13 | #2 Yes, provided you don't want to use the group mode. As long as you use the functions you can get with the 580 EX II (using optical communication), you can do the same with the 600 EX-RT via radio, regardless of the camera. Anders
dmward Cream of the Crop More info | Feb 17, 2014 13:59 | #3 If you want to use all the 600EX-RT system capabilities with older cameras, the only available solution is the YongNou YN-E3 controller. It offers complete Gr mode support for earlier cameras such as those you listed. David | Sharing my Insights, Knowledge & Experience
WavyC Senior Member 857 posts Likes: 5 Joined Jan 2005 Location: Belfast, Northern Ireland More info | Feb 17, 2014 14:40 | #4 The 600ex manual also states that the flash sync speed is one increment lower when using with a pre-2012 camera (so in the case of your 1D cameras 200/sec rather than 300/sec).
dmward Cream of the Crop More info | Feb 17, 2014 15:18 | #5 apersson850 wrote in post #16696463 ... with some limitations. What limitations are you thinking about? David | Sharing my Insights, Knowledge & Experience
Feb 17, 2014 16:07 | #6 Thanks everyone for the help. Again looking at the Canon 600RT users manual it gets confusing on page 51 about any camera 2011 or earlier stating radio mode e-ttl isn't possible. I called Canon tech support and they're saying it's a typo. 1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
Feb 17, 2014 16:42 | #7 cristphoto wrote in post #16696885 Thanks everyone for the help. Again looking at the Canon 600RT users manual it gets confusing on page 51 about any camera 2011 or earlier stating radio mode e-ttl isn't possible. I called Canon tech support and they're saying it's a typo. The manual also states on pg 51 (see below) that wireless HSS shooting is not possible. So far no one has had an issue not being able to use HSS nor has the shooting at max sync speed been an issue. You get a very slight shadowing at the bottom of the image but is not that noticeable. Image hosted by forum (677367) © agv8or [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Rand
dmward Cream of the Crop More info | Feb 17, 2014 16:44 | #8 cristphoto wrote in post #16696885 Thanks everyone for the help. Again looking at the Canon 600RT users manual it gets confusing on page 51 about any camera 2011 or earlier stating radio mode e-ttl isn't possible. I called Canon tech support and they're saying it's a typo. It must be a typo, I was shooting a wedding yesterday and 2 of my associates were using per-2012 cameras that worked just fine with 600EX-RTs for ETTL. Both on camera and via radio for remote. David | Sharing my Insights, Knowledge & Experience
digitalparadise Awaiting the title ferry... More info | Feb 17, 2014 18:52 | #9 People have said that is is working in other threads. Canon may have put that in just to cover themselves. Perhaps they found some bodies that did not work. I'm not sure but most of the feedback has been positive. Image Editing OK
aam1234 Goldmember 4,132 posts Likes: 1 Joined May 2004 More info | Would a pre-2012 camera fire multiple 600 RTs using the ST-E3-RT Transmitter.
digitalparadise Awaiting the title ferry... More info | Feb 18, 2014 21:43 | #11 That will work just fine. Reports are that it will fire at sync speed as discussed. No group mode. Yongnuo has released the the YN-E3-RT which is compatible with the 600 RTs and has group mode I think. I own the ST-E3-RT so I don't really know. I'll find a thread on that for you or someone can answer that. Image Editing OK
digitalparadise Awaiting the title ferry... More info | Feb 18, 2014 21:45 | #12 https://photography-on-the.net …/showthread.php?t=1348512 Image Editing OK
aam1234 Goldmember 4,132 posts Likes: 1 Joined May 2004 More info | Feb 19, 2014 00:26 | #13 Thanks, DP
apersson850 Obviously it's a good thing More info | Group mode is one thing. It allows fully independent settings for flashes in different groups. Anders
dmward Cream of the Crop More info | Feb 19, 2014 07:30 | #15 aam1234 wrote in post #16700696 Thanks, DP But if there is no group mode how can one control multiple flashes. Sorry for the basic question. When using pre-2012 cameras, the 600EX-RT system works the same way the optical ETTL-II system works. It just adds the radio communication capability. Or it can continue with the optical communication capability. David | Sharing my Insights, Knowledge & Experience
| Latest registered member is semonsters 1154 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
