Thread started 18 Feb 2014 (Tuesday) 04:14
1d Mk3 burst limit
jock3
Gallery: 13 photos
Feb 18, 2014 04:14 |  #1
I'm asking this for an elderly friend who isn't on line. He has a 1d MK3 and regardless of what he does the max number of shots the viewfinder says are available are 15 regardless of the camera being set for Jpeg or RAW. The camera works perfectly otherwise. Can anyone make any suggestions whats the reason?
He suspects he may be responsible by in getting to know the cam having made an unintentional change.
Most Canons currently - 1D(Mks 2&3&4), 7D gripped 50D gripped x2, 40Dgripped x2, 30Dgripped, 20D gripped, 350 gripped, 300. with L lenses
WEBSITES - http://knockhillimages​.smugmug.com/ (external link)
& http://aviationandmari​timeimages.smugmug.com​/ (external link)
apersson850
Obviously it's a good thing
Gallery: 35 photos
Feb 18, 2014 06:17 |  #2
Has he limited the burst length by the custom function for that? That's possible to do on the 1D Mark III. However I don't know if it will show the setting in the viewfinder, but if I set the 1DX to a max burst length of 15, then it immediately shows 15 in the viewfinder, instead of 62, which was there the moment before I limited the burst length. Removing the limit and I see 62 again.
Anders
jock3
Gallery: 13 photos
Feb 18, 2014 06:30 |  #3
Just phoned him and his answer is "not deliberately anyway" I told him to do the "clear camera settings" but he says he did that and it makes no difference
rrblint
Gallery: 84 photos
Joined May 2012
Feb 18, 2014 07:46 |  #4
jock3 wrote in post #16698426 (external link)
He needs to clear all custom functions as well.
Mark
apersson850
Gallery: 35 photos
Feb 18, 2014 08:13 as a reply to  @ rrblint's post |  #5
Is there no user's manual with his camera? Took me 30 seconds to see that it's custom function III.17 he should check.
Anders
Paulstw
Joined Nov 2012
Feb 18, 2014 08:40 |  #6
One extra thing to note is that you'll get a reduced burst rate if using a higher ISO. Says it in the manual.
jock3
Gallery: 13 photos
Feb 18, 2014 08:44 |  #7
I don't know if he has a manual, but I'm going along shortly and will pass the info on. Thanks all
adamo99
Gallery: 6 photos
Feb 18, 2014 10:16 |  #8
Check highlight tone priority also.
apersson850
Gallery: 35 photos
Feb 18, 2014 13:57 as a reply to  @ adamo99's post |  #9
Why? It has no influence whatsoever on neither burst length nor rate.
Anders
adamo99
Gallery: 6 photos
Feb 18, 2014 16:23 |  #10
apersson850 wrote in post #16699390 (external link)
It does on mine. Also, it slows down at higher ISOs, as mentioned above.
DarenM
Feb 18, 2014 17:43 |  #11
What size card does he have in the camera? Could he have put a small card in by mistake? Would this cause the problem?
Canon 1D MK IV, Canon 1D MK III, Canon 5D, 24-70 2.8L, 70-200 2.8 L IS MK II, 17-40 F4 Canon, 430 EX, Canon A2E, 530EX Canon 1.4 Extender, 580 II, 600EX-RT, ST-E3-RT, (Way too much stuff for an amateur)
jock3
Gallery: 13 photos
Feb 18, 2014 17:49 |  #12
Just to say with my own handbook stuck in my caravan until the campsite reopens after the winter shutdown with reference to the above posts I got the old boy sorted out tonight and he says a a massive thanks!
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Feb 18, 2014 17:54 |  #13
good result - strongly recommend the first setting changed after clearing all camera settings is to set "shoot w/o card" to OFF...
TF posting: here :-)
apersson850
Gallery: 35 photos
Feb 19, 2014 01:55 |  #14
adamo99 wrote in post #16699759 (external link)
Higher ISO, yes. But I've never noticed any difference due to highlight tone priority. Which camera do you have?
Anders
adamo99
Gallery: 6 photos
Feb 19, 2014 09:02 |  #15
apersson850 wrote in post #16700784 (external link)
A Canon T70. Why would I comment about a different camera than the OP is asking about?? :rolleyes:
3,539 views & 0 likes for this thread, 9 members have posted to it and it is followed by 2 members.
1d Mk3 burst limit
2210 guests, 124 members online
