Thread started 18 Feb 2014 (Tuesday) 16:08
450D Err 99
tambler
Joined Feb 2014
Feb 18, 2014 16:08 |  #1
Camera allows me to take 1 photo then Err 99 comes up tells me to turn power to to off and on again or re-install the battery. Do this and it repeats. Or if I just leave it the same happens. Then the screen is blank no image shown, however, there is a picture on the card.
I have searched on line and followed the advice to clean the contacts on the lens and camera, change to another lens, remove and charge the battery, change card all to no avail.
Does anyone have any other ideas please?
lota420
Joined Jan 2014
Feb 18, 2014 16:16 |  #2
did u remove the small battery?
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Feb 18, 2014 16:18 |  #3
Error 99 is the general fault error so it could be any number of problems, including an issue with the lens, memory card, or something more sinister. Its probably time to have it checked out.
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Feb 18, 2014 21:52 |  #4
couple of things to test to at least narrow the issue down, firstly try shooting without a lens at all & see if error happens still.
If error still occurs, with lens still off, set camera to mirror lock-up mode, and try a test shot (needs shutter pressed twice - first to lock up the mirror, second to take the shot)
p.s welcome to the forums...
TF posting: here :-)
watt100
Feb 19, 2014 05:48 |  #5
tambler wrote in post #16699719 (external link)
is there a large black or white area on the recorded photo?
like others have said, it could be any number of things including a bad shutter
Ingerson"PCD"
Gallery: 96 photos
Feb 19, 2014 05:53 |  #6
Try reformatting your SD card in camera. I had this happen to mine if I remember correctly.
-Eric-
I have too many hobbies to be good at any of them.
tambler
Joined Feb 2014
Feb 23, 2014 04:18 |  #7
Thanks for suggestions, unfortunately none of them have worked. The only one haven't tried is removing the small battery. No idea how to do this.
1,032 views & 0 likes for this thread, 6 members have posted to it.
450D Err 99
2216 guests, 124 members online
