Thread started 19 Feb 2014 (Wednesday) 08:42
CTO first timer, how do I know which temp to get? Pic inside
digitalduck
Joined Aug 2013
Feb 19, 2014 08:42 |  #1
Woops, didn't see another post of mine below this one, sorry
So I have a shoot this weekend and am looking to replicate the feel here because it will be under the same lights. I'm not sure which cto to try first (1, 1/2 etc)
Thank you!
IMAGE: http://www.acoloradocourtship.com/wp-content/uploads/2013/05/Downtown-Engagement-09.jpg
digitalduck
Joined Aug 2013
Feb 19, 2014 13:42 |  #2
Buying this afternoon if anyone has any advice :)
sportmode
Joined Nov 2010
Feb 19, 2014 13:57 as a reply to  @ digitalduck's post |  #3
1/4 CTO is enough for me when I'm shooting events. I don't want to warm up the faces too much.
5D Mark III, 6D, EOS-M 22mm f/2 | 24-70mm f/2.8L II | 50mm f1.4 | 100L | 70-200mm f/2.8L IS II | Rokinon 8mm Fisheye
digitalduck
Joined Aug 2013
Feb 19, 2014 14:06 |  #4
Thanks Sportmode, Ill try 1/4 to start with.
gonzogolf
dumb remark memorialized
Gallery: 40 photos
Feb 19, 2014 14:21 |  #5
I agree. The key here is you are just trying to eliminate the mismatch between the flash and the ambient. So you can do it in baby steps if you wish. 1/4 CTO warms the flash (or if you correct totally for the face you are in truth cooling the ambient) a bit. The problem you have here is that you have multiple sources of ambient each with its own color so matching is an imprecise art anyway.
dmward
Gallery: 29 photos
Feb 19, 2014 16:39 |  #6
I agree with others that 1/4 or even 1/8th is good for this situation. I have 1/8, 1/4, and 1/2. Can't remember when I've used the 1/2. Almost always 1/8, sometimes 1/4. As Gonzo points out often with the 1/4 when getting the skin right the ambient is just a bit too blue.
starlights
Gallery: 16 photos
Joined Apr 2011
Feb 20, 2014 08:25 |  #7
If you get 1/4 - you can always double (fold it over) it to get 1/2
If you plan to use these on regular speedlights, it may be worth getting a pack of Rosco Cine Gel Samples - that comes in a booklet form and has all different (over a 100) different types of gel samples which fit perfectly on the speedlight heads - a good way to try out the different ones for cheap or free.
Strobo
Joined Sep 2013
Feb 20, 2014 11:32 |  #8
digitalduck wrote in post #16701202 (external link)
So I have a shoot this weekend and am looking to replicate the feel here because it will be under the same lights. I'm not sure which cto to try first (1, 1/2 etc)]
Starting out with a smaller strength is good to begin with. As Starlights mentioned, you can stack the gels to increase their strength. I usually buy only 1/8 and 1/2 strength. Two layers of 1/8 = 1/4, two layers of 1/2 = full.
If you find the skintones a bit too orange-ish with the CTO filters try a CTS (straw) for a bit more of a pinkish hue.
1,084 views & 0 likes for this thread
Latest registered member is Ivy Yeh
583 guests, 225 members online
