Thread started 19 Feb 2014 (Wednesday) 09:55
Photoshop CC bug
groundloop
Joined Jun 2012
Feb 19, 2014 09:55 |  #1
Forgive me if this has been covered before, I searched and didn't find anything.
I just signed up for the Lightroom / Photoshop CC bundle for $10/month and have been working my way through learning Photoshop (I've gotten fairly proficient with Gimp so my transition is going pretty fast). I discovered that the lasso and magnetic lasso tools don't work right in that hitting the 'backspace' key won't undo the last point selected and hitting 'escape' won't get you out of the lasso tool. At first I assumed that I had accidentally screwed up a setting somewhere, but lo and behold this is a problem that Adobe knows about - I find it pretty surprising that they'd release software with this major of a bug.
From what I understand I can uninstall Photoshop CC and the install CS6 from the Adobe Cloud and use that until Adobe fixes the bug. Will I be giving up much functionality by doing that?
kirkt
Feb 19, 2014 10:32 |  #2
groundloop wrote in post #16701387 (external link)
An update to CC was issued today that fixes the backspace bug:
http://blogs.adobe.com …update-now-available.html (external link)
Have you updated?
Photoshop 14.2.1 Update (2/18/2014)
2/18/2014 – Today we released Photoshop CC update version 14.2.1 (for Creative Cloud members, Mac and Windows), resolving the following issues:
Fixed issue where Smart Object is not updating correctly after going back in history with parent document
Fixed issue with Generator and Linked Illustrator Smart Objects
Fixed issue where bounds of layers exported via Generator are wrong
Fixed program errors when Generator is enabled
[B]Fixed issue where backspace key doesn’t delete last point for Polygonal Lasso, Magnetic Lasso, Magnetic Pen [/B]
Fixed issue where Generator stops generating files in documents with a large number of layers
Fixed coordinate incompatibility between 14.0 and 14.2 when using 3D/actions
Improved start-up time when scanning presets
Fixed issue where clipboard is not retaining the correct size unless the resolution is set at 72 when copied from Illustrator
Fixed issue with Smart Object updating incorrectly after drag and drop between unsaved documents
Fixed issue rendering PSDs with 3D content created in prior versions
Fixed issues errors, stability, and rendering issues with Scripted Pattern Fill
Fixed crash on quit after creating video Smart Object
Fixed stability issue when running Camera Shake Reduction filter on new Mac Pro
Fixed issue with context menus not working on Windows (document titlebar, unit menu on w & h during transform, etc)
Fixed issue where New Linked Smart Object via Copy layer updates wrong Smart Object after edit
Fixed issue with inverted bump maps
Fixed several crashing issues using Generator
Fixed crashing issue build 3D print for Shapeways 3D print
Fixed 3D issue with rendering after unchecking Surface Detail
Fixed 3D crash when default presets are missing
Fixed crashing issue when saving and closing document quickly after applying a filter
Fixed issue with merging down 3D extrusion Material
Fixed crashing issue with 3D cross-sections
Fixed issue with placing linked Smart Object containing animation/motion
Fixed issue when placing 3D files using Javascript
kirk
Kirk
kirkt
Feb 19, 2014 10:36 |  #3
Also - if you already own CS6 you can leave it on your machine right next to CC. There is no need to uninstall CS6.
kirk
Kirk
groundloop
Joined Jun 2012
Feb 19, 2014 10:37 |  #4
kirkt wrote in post #16701445 (external link)
Well that was good timing. I'll look at that when I get home from work tonight.
kirkt
Feb 19, 2014 10:49 |  #5
People bitched and moaned about the CC subscription model, but bugs are addressed and updates are issued at a furious pace compared to any other version of PS I can remember.
You win!
kirk
Kirk
1,992 views & 0 likes for this thread, 2 members have posted to it.
Photoshop CC bug
1324 guests, 110 members online
