Thread started 19 Feb 2014 (Wednesday) 17:31
14mm 2.8L or the 24 1.4L?
Gel
Joined Sep 2009
Feb 19, 2014 17:31 |  #1
I'm off to Tenerife to shoot some stars by the Observatory there and it's my third time.
Usually I rely on the 16-35 on the 1DX, But I'm after a cleaner image with less vignetting wide open.
For those in the know, would the 14mm be a better choice than the 24mm prime even though the latter is faster?
As a secondary question, can anyone recommend a simple, lightweight idiot proof tracking system to avoid trailing please?
Thanks!
Chris Giles Photography
Toxic ­ Coolaid
Feb 19, 2014 20:43 |  #2
I'd go for the 14mm. But that's because I like the wider FOV. You should always shoot at f/4 or higher to reduce star bloat. The Astrotac or Polarie are good portable trackers
samsen
Feb 19, 2014 21:17 |  #3
I don't own 24mm L and have no experience with it but I can swear by my Rokinon 14mm F2.8 or my Tokina 11-16 F2.8 for astrophotography.
BTW are you shooting on a cropped or FF body? I am asking this because you are concern with Vignette but let me tell you if you think Vignetting is getting worse with Wide open F, you are totally mistaking.
As for Tracker, what is your payload? If you are considering a small ultra wide angle as said and a normal weight body, 2 good choices:
1- iOptron 3302B
2- Vixen Optics 35505
Both are good. Both are the lightest weight mounts. First one comes with illuminated polar scope in the basic package and should cost you well under $400. Second one is more expensive (Not necessarily better) is just under $400 but has only a simple hole for rough polar alignment. If you are to buy accessory Polar scope, that will cost you an additional $130 to 150 to make it equivalent of the first one so its about $150 more.
Amazon has both but if you find my advice useful, please do NOT buy from Adorama. I hate them.
Weak retaliates,
Strong Forgives,
Intelligent Ignores!
Samsen
Picture editing OK
Gel
Joined Sep 2009
Feb 22, 2014 07:55 |  #4
Samsen, it's going on a 1DX.
Trying to obtain an Astrotrac too.
samsen
Feb 22, 2014 10:03 |  #5
1DX is heavy.
You need to look into something stable.
I would personally piggyback that on my large autostar glass but there are many users here with hand on experience on exactly what you need to know. Let see what else Mo, Wes,
Madweasel and others are having to say.
Weak retaliates,
Strong Forgives,
Samsen
Picture editing OK
1,299 views & 0 likes for this thread, 3 members have posted to it.
1452 guests, 137 members online
