My wife's boss wants some prints with the name of the person pictured under the photo. White lettering on a black background. Have never added print to a picture before, is this possible in LR? Thanks
ralff Senior Member 766 posts Joined May 2008 Location: Asheville NC More info | Feb 21, 2014 08:26 | #1 My wife's boss wants some prints with the name of the person pictured under the photo. White lettering on a black background. Have never added print to a picture before, is this possible in LR? Thanks Canon 6D - Canon 7D - gripped, Canon 50D - gripped, EFS10-22mm, 17-40 f4 L, nifty-fifty, EF 28-135mm IS, 100-400 f4.5-5.6 L IS USM, Tokina AT-X 100mm f/2.8 ProD Macro, Benbo Trekker, Feisol 3371 w/ Kirk BH-3 ball head - Epson Pic-Mate, Epson 2200, Epson 3880
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Feb 21, 2014 08:52 | #2 You can do a limited amount of text. A name under the photo is easy, but making it white on black would require creating it in another application and applying it as a graphic identity plate or watermark. For black on white select Photo Info and Custom Text and type in the name. Elie / אלי
Feb 21, 2014 22:49 | #3 The black background you speak of - I'm assuming you are talking about adding that to the photo, and it's not part of the actual original picture? In which case, as Eli said, it won't be incredibly easy. Canon eos7D | Canon 50mm 1.4 | Canon 17-55mm 2.8 | Sigma 70-200mm 2.8 | Yongnuo 565ex | Yongnuo yn-468 II | Canon ef28-135mm 3.5/5.6 | Canon ef-s 55-250mm 4.0/5.6
I do also have an older copy of elements, ver. 9 I believe, is there any way to do this in elements? Canon 6D - Canon 7D - gripped, Canon 50D - gripped, EFS10-22mm, 17-40 f4 L, nifty-fifty, EF 28-135mm IS, 100-400 f4.5-5.6 L IS USM, Tokina AT-X 100mm f/2.8 ProD Macro, Benbo Trekker, Feisol 3371 w/ Kirk BH-3 ball head - Epson Pic-Mate, Epson 2200, Epson 3880
Agged Senior Member 285 posts Likes: 9 Joined Sep 2008 Location: British Columbia More info | Is there a Text Tool in Elements v.9? If so, that should work fine. Flickr
scriveyn Goldmember More info | If LR supports Photoshop Plugins (.8bf), then this "Graphic Spell" plugin is an option: www.westbrookjazz.de/filter/f0.html Frank, also known as jazzman
tonylong ...winded More info | Feb 23, 2014 15:31 | #8 There is a plug-in for Lightroom that has been used for a long time but I forget its name...? Tony
PixelMagic Cream of the Crop 5,546 posts Likes: 6 Joined Nov 2007 Location: Racine, WI More info | Feb 23, 2014 15:53 | #9 Check out the LR/Mogrify 2 plug-in: http://blogs.adobe.com …er-8-1-now-available.html
tonylong ...winded More info | Feb 23, 2014 17:07 | #10 Ah, yes, Mogrify is the plug-in I was thinking about! A lot of folks here have found it very useful in extending things beyond the limits of Lightroom! Tony
| Latest registered member is zachary24 1405 guests, 128 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
