Thread started 21 Feb 2014 (Friday) 19:49
TS-E 24mm II shift to side and up?
davidfarina
Gallery: 43 photos
Joined May 2013
Feb 21, 2014 19:49 |  #1
Is it possible to shift this lens lets say the maximum to the left and at the same time shifting it to the top? Or do i have to rotate the lens? Is it even possible to shift it in all 4 directions?
Sony A7RII | Sony A7S
EF 40 | EF 70-300L | FD 35 Tilt-Shift
FE 16-35 | FE 28 | FE 90
CV 15 4.5 III | CV 40 1.4 MC | Summilux 50 ASPH
Website (external link) | 500px (external link)
WhyFi
Gallery: 246 photos
Location: I got a castle in Brooklyn, that's where I dwell.
Feb 21, 2014 21:53 |  #2
You need to rotate the lens - they only shift along one axis, but you can rotate the lens (detents at 30°) to change that axis. With the rotation, the shift coverage area is a circle with the radius defined by the max shift, not a square as you were apparently imagining; it'll cover most of the area that you were thinking about.
Bill is my name - I'm the most wanted man on my island, except I'm not on my island, of course. More's the pity.
Mike ­ K
Joined Apr 2001
Feb 22, 2014 00:43 |  #3
Yes, you can only shift back and forth in one axis at a time. However, relative to the body this also means by rotating the lens diagonal to the body one can shift in a diagonal direction. Some older Oly designs that were shift only allowed shifts in horizontal and vertical directions at once. However this is in effect a diagonal shift which the Canon lens can replicate via rotating before shifting.
perhaps the images in this lens review will help
http://www.dpreview.co​m …ws/canon_24_3p5​_tse_c10/2 (external link)
Are you trying to do a shift pano in two directions? this does work by rotating the lens to a diagonal position, maximum shift, then shooting the 4 corners of the pano at 45, 135, 225 and 315 degrees relative to the camera position. Then stitch. 6 position panos can also be done this way.
Mike K
Canon 6D, 1DmkII, IR modified 5DII with lots of Canon L, TSE and Zeiss ZE lenses
davidfarina
Gallery: 43 photos
Joined May 2013
Feb 22, 2014 06:59 |  #4
Mike K wrote in post #16708203 (external link)
Mike K
Nice review thx for the link
No im just wondering if i could do it in case i need a wider angle than the FOV of 24mm. What FOV can it mimic at the max shifts? About what a 20mm gives or how much?
Canon ­ Bob
Feb 22, 2014 10:56 |  #5
davidfarina wrote in post #16708467 (external link)
If you mean AOV, not FOV, then it's about 102 degrees (h) and roughly equal to a 14mm lens.
Bob
1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
davidfarina
Gallery: 43 photos
Joined May 2013
Feb 22, 2014 12:36 |  #6
Canon Bob wrote in post #16708802 (external link)
Bob
Wow that much? Great haha
Thanks guys now i go out and practice :)
2,065 views & 0 likes for this thread, 4 members have posted to it.
1605 guests, 142 members online
