I'm so into "pancake lenses" after buying a compact SL1 with 40mm pancake. This kit is simply awesome for light travels.
but i WISH they would make some more pancake lenses now. something like a 24mm or a wider 18mm pancake.
eh???
datadump Goldmember 1,932 posts Joined Oct 2007 Location: Canada More info | Feb 21, 2014 22:52 | #1 I'm so into "pancake lenses" after buying a compact SL1 with 40mm pancake. This kit is simply awesome for light travels. datadump
maverick75 Cream of the Crop More info | Feb 21, 2014 23:03 | #2 |
Feb 21, 2014 23:05 | #3 maverick75 wrote in post #16708078 The 22mm 2.0 is an absolute dream. Too bad its only In EF-M mount. exactly! datadump
maverick75 Cream of the Crop More info | Feb 21, 2014 23:39 | #4 |
maverick75 Cream of the Crop More info | Feb 21, 2014 23:40 | #5 |
Ginga Senior Member 370 posts Likes: 1 Joined Feb 2013 Location: Jokkmokk - Sweden More info | A 17mm full frame pancake would be nice. Sony A7R * 70-200 2.8L II * 24-70L II * Samyang 14
maverick75 Cream of the Crop More info | Feb 23, 2014 20:38 | #7 Well I kinda stumbled onto another pancake option for us, it's really affordable also. - Alex Corona Sony A7, Canon 7DM2/EOS M, Mamiya 645/67
Shadowblade Cream of the Crop More info | Feb 27, 2014 09:59 | #8 I'd like a pancake supertelephoto lens, to use in all those places where you 'can't take big lenses' (e.g. cricket matches). Most likely, it would need DO technology.
watt100 Cream of the Crop 14,021 posts Likes: 34 Joined Jun 2008 More info | Feb 27, 2014 17:15 | #9 Shadowblade wrote in post #16721616 I'd like a pancake supertelephoto lens, to use in all those places where you 'can't take big lenses' (e.g. cricket matches). Most likely, it would need DO technology. Doesn't matter if it's 150mm wide - so long as it's physically short! good idea, I'd like a pancake 400mm
vengence Goldmember 2,103 posts Likes: 108 Joined Mar 2013 More info | Mar 02, 2014 18:26 | #10 watt100 wrote in post #16722631 good idea, I'd like a pancake 400mm They make a 400mm DO...
Mar 02, 2014 18:46 | #11 vengence wrote in post #16729708 They make a 400mm DO... http://www.usa.canon.com …_do_is_usm#Specifications That's a pretty big pancake. More like a flapjack, IMO -- Mark | Gear | Flickr
vengence Goldmember 2,103 posts Likes: 108 Joined Mar 2013 More info | Mar 02, 2014 19:40 | #12 The 400 DO is 233mm for a 400mm focal length, the 40mm pancake is 22.8mm. Damn close to the same ratios
RHChan84 Goldmember 2,320 posts Likes: 24 Joined Apr 2011 Location: Mass More info | Mar 04, 2014 09:13 | #13 |
TheDarkKnight Goldmember 1,194 posts Likes: 49 Joined Apr 2012 More info | Mar 04, 2014 11:26 | #14 Wasn't there a rumor about an EF-S 24mm lens? If true, if not pancake, I would assume it's a very compact design, probably f/2.8. Sounds awesome on an APS-C Canon.
Shadowblade Cream of the Crop More info | Mar 04, 2014 11:32 | #15 vengence wrote in post #16729886 The 400 DO is 233mm for a 400mm focal length, the 40mm pancake is 22.8mm. Damn close to the same ratios ![]() There's no theoretical reason it can't be made even shorter. 100mm or shorter in length would be good.
| Latest registered member is semonsters 1463 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
