I'm expereimenting with shooting in AV mode (heretofore strictly a M shooter) & would like to know, is there a way to set a limit for ISO on both the MKII & MKIII? Is there already a default max ISO on both or either in AV?
Feb 23, 2014 12:01 | #1 I'm expereimenting with shooting in AV mode (heretofore strictly a M shooter) & would like to know, is there a way to set a limit for ISO on both the MKII & MKIII? Is there already a default max ISO on both or either in AV? Michelle Brooks Photography
Feb 23, 2014 12:12 | #2 You would need to set the ISO to Auto, which can be done in any of the top dial shooting modes. I have a 5DIII and personally avoid going over 12,800.
thedcmule2 Goldmember 1,125 posts Likes: 3 Joined Nov 2011 More info | Feb 23, 2014 16:27 | #3 Go into the settings, you can set all that in the "ISO speed range", not sure if its available on the mark ii though
Feb 23, 2014 16:32 | #4 Found it on the MKIII but not the MKII Michelle Brooks Photography
gonzogolf dumb remark memorialized More info | Feb 23, 2014 16:52 | #5 Just curious why you are sooting auto iso in av mode?
Feb 23, 2014 16:56 | #6 I just downloaded the manual to the mkII. It looks like Auto ISO will use a range of 100-3200 in greenbox, CA, P, Tv, and Av mode. I don't see anything about limiting the range like the mkIII can so.
kin2son Goldmember 4,546 posts Likes: 3 Joined May 2011 Location: Sydney, Australia More info | Feb 23, 2014 17:02 | #7 Permanent bangonzogolf wrote in post #16711626 Just curious why you are sooting auto iso in av mode? I have also start experimenting with Av lately. Auto ISO is definitely the best way to go. 5D3 Gripped / 17-40L / Σ35 / 40 Pancake / Zeiss 50 MP / Σ85 / 100L Macro / 70-200 f2.8L II IS / 430 EX II / 580 EX II / Canon 2xIII TC / Kenko Ext. Tubes
gonzogolf dumb remark memorialized More info | Feb 23, 2014 17:06 | #8 kin2son wrote in post #16711642 I have also start experimenting with Av lately. Auto ISO is definitely the best way to go. I have Av, min ss set and +1 and 2/3 EC dial in. It's almost bullet proof. And thats better than a fixed iso how? You are surrenering control of both SS and ISO, why not fix the ISO and only have one wildcard?
thedcmule2 Goldmember 1,125 posts Likes: 3 Joined Nov 2011 More info | Feb 23, 2014 17:13 | #9 Auto ISO is definitely the best way to go because sometimes the shutter speed needs more room to play with and a fixed ISO means it cant always meet the metering demand (ESPECIALLY if you need a +1 compensation without having the shutter speed go too slow, like 1/10 or slower is completely useless sometimes when im handholding and shooting people).
Feb 23, 2014 17:25 | #10 thedcmule2 wrote in post #16711667 on the mark iii you can set minimum and maximums for iso and ss, so it's quite bulletproof indeed. I just wish I could set the min SS higher than 1/250. I like to shoot at 1/500 for freezing action.
EverydayGetaway Cream of the Crop More info | Feb 23, 2014 17:48 | #11 gonzogolf wrote in post #16711650 And thats better than a fixed iso how? You are surrenering control of both SS and ISO, why not fix the ISO and only have one wildcard? How is it a wildcard? If you know how to read and set your metering you can get very accurate results using auto ISO and Av. Using MF glass I frequently use Av and auto ISO, I'd say 80% of the time. It's convenient and accurate, the most I ever feel the need to adjust in post is plus or minus .20 for exposure in LR. I find that Auto ISO is implemented much better in Av than it is in M since you can also control your exposure compensation, which you can't do in M mode on anything but the 1DX. Fuji X-T3 // Fuji X-Pro2 (Full Spectrum) // Fuji X-H1 // Fuji X-T1
kin2son Goldmember 4,546 posts Likes: 3 Joined May 2011 Location: Sydney, Australia More info | Feb 23, 2014 18:00 | #12 Permanent bangonzogolf wrote in post #16711650 And thats better than a fixed iso how? You are surrenering control of both SS and ISO, why not fix the ISO and only have one wildcard? Because the camera will always pick the lowest ISO required with auto ISO. 5D3 Gripped / 17-40L / Σ35 / 40 Pancake / Zeiss 50 MP / Σ85 / 100L Macro / 70-200 f2.8L II IS / 430 EX II / 580 EX II / Canon 2xIII TC / Kenko Ext. Tubes
gonzogolf dumb remark memorialized More info | Feb 23, 2014 18:01 | #13 EverydayGetaway wrote in post #16711750 How is it a wildcard? If you know how to read and set your metering you can get very accurate results using auto ISO and Av. Using MF glass I frequently use Av and auto ISO, I'd say 80% of the time. It's convenient and accurate, the most I ever feel the need to adjust in post is plus or minus .20 for exposure in LR. I find that Auto ISO is implemented much better in Av than it is in M since you can also control your exposure compensation, which you can't do in M mode on anything but the 1DX. Its a wildcard, perhaps you are more comfortable with word variable, but the camera is picking two of the 3 variables of the exposure triangle.
EverydayGetaway Cream of the Crop More info | Feb 23, 2014 18:11 | #14 gonzogolf wrote in post #16711785 Its a wildcard, perhaps you are more comfortable with word variable, but the camera is picking two of the 3 variables of the exposure triangle. Not really, it's picking them with your approval. If you don't like the settings it's showing, you simply dial in exposure compensation, which even that I rarely have to do. Fuji X-T3 // Fuji X-Pro2 (Full Spectrum) // Fuji X-H1 // Fuji X-T1
JohnSheehy Goldmember 4,542 posts Likes: 1215 Joined Jan 2010 More info | Feb 23, 2014 18:13 | #15 EverydayGetaway wrote in post #16711750 How is it a wildcard? If you know how to read and set your metering you can get very accurate results using auto ISO and Av. Using MF glass I frequently use Av and auto ISO, I'd say 80% of the time. It's convenient and accurate, the most I ever feel the need to adjust in post is plus or minus .20 for exposure in LR. I find that Auto ISO is implemented much better in Av than it is in M since you can also control your exposure compensation, which you can't do in M mode on anything but the 1DX. You can simulate M with EC and auto-ISO on some of the newer cameras, if your desired Av value is wide-open, by:
Then, the ISO will read the one you set it to until you take the shot, and then it will be automatically lowered to avoid over-exposure, based on the lighting and your EC setting. This also works with flash, and is the only way to get fill flash with auto-ISO, M, and EC on my 6D. You could also use a manual-aperture lens in Tv mode, and get all of the features of Tv mode in simulated M mode.
| Latest registered member is semonsters 1596 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
