Thread started 25 Feb 2014 (Tuesday) 11:40
Whats the lowest cost optical flash you know of
Littlejon ­ Dsgn
Joined Feb 2012
Feb 25, 2014 11:40 |  #1
I had a friend over last night, playing around in the new studio space. I have two of the "slave bulbs" that I use to blow out backgrounds, well I pulled the black background out and turned the bulbs to face the camera and played around with the "rock star" effect.
However my wife/assistant knocked over one of the stands and the bulb had a hard meeting with the cement floor. So I need to pick up another of those, but got to thinking maybe there is a cheaper smaller maybe not so bright alternative I could use for only this lighting effect.
So here is what I used last night
http://www.adorama.com​/LTACS.html (external link)
I know they are not expensive but add the holder to it and it starts to add up a bit. They are also just to bright for what I really want to use them for.
Suggestions on cheaper flash units
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Feb 25, 2014 11:43 |  #2
It doesnt get any cheaper than that. I suppose if you hit thrift shops and found some old flashes and bought optical slaves you might save a bit but its not an instant solution by any means.
Littlejon ­ Dsgn
Joined Feb 2012
Feb 25, 2014 11:53 as a reply to  @ gonzogolf's post |  #3
Kinda figured as much, one stupid question, the units I have are a guide number of 26 at ISO 100. I found some real cheap (probably quality) as well as cost on ebay that I might give a shot. If the guyid number is higher then 26 at IS0 100 then it will be a brighter flash right?
Ok found the answer so never mind that questions
679 views & 0 likes for this thread, 2 members have posted to it.
1502 guests, 131 members online
